I'm currently trying to communicate with a seller in Germany for the correct UK spec lights for Australia. The inner left & right part numbers are different to the rest of Europe. The parts needed for Australia with the fog light on the right are
5K0945093Q (Inner Light Left)
5K0945094Q (Inner Light Right)
5K0945095L (Outer Light)
5K0945096L (Outer Light)
Adapter cables are also needed as the R lights have a different connector to standard Golfs.
Coding with Vagcom will also be required. AFAIK the Kufatec box is only for LHD or European spec.
See here for more info http://www.mk6golfgti.co.uk/forum/in...opic,81.0.html
