Page 116 of 118 FirstFirst ... 1666106114115116117118 LastLast
Results 1,151 to 1,160 of 1178
Thread: Mk6 LED Taillights
  1. #1151
    South East, SA
    Quote Originally Posted by AdamD View Post
    JKU highlights the required module because not all Golfs (overseas particularly; low-spec models) are fitted with this part. However I'm 99.9% sure you'll have a highline CECM and compatible revision already. We've done this on dozens of cars that I know of (including TDIs), and I have personally coded several Golfs and GTIs. Wait till you can get a VCDS scan of your car so we can verify the part and revision numbers..
    Ah ok that makes sense. I think I'll do the scan first before deciding what I need.
    Will work on the RVC before doing at the tail lights.
    MY17 Arteon | 206TSI R-Line | Manganese Grey Metallic | Front window tint 35% | Stage 1: ECU Racing Line tune, DSG APR tune, R600 intake bundle |
    MY12 GOLF Mk6 103TDI Comfortline | Shark Blue | RD Technik Stage 1 Tune | DSG Tune | RNS510 | Highline RVC | Window tint 35% | GTI steering wheel |
    See build: http://www.vwwatercooled.com.au/foru...ild-99394.html
  2. #1152
    Oct 2014
    Could anyone suggest where I could find an OEM set for a decent price? I have checked Jku and Boldsport as mentioned throughout the thread, but both are near $1k shipped which is too steep for me. I really am against a set of replicas such as CT autoparts ($400~), but the price difference is too big.
    Also, if anyone does have replicas, could you please advise me on the quality and reliability of the set.
    Thanks!
  3. #1153
    Jul 2014
    Cool Led mk6 rear light code
    Hi,
    Need help on getting the code for my LED rear's i have recently fitted to my GTI, so i can get the warning light to go off. Where do i start to find out getting this information? i thought these lights were play n play? they are OEM and not copy's.
    Thanks
    John
  4. #1154
    Oct 2014
    This should be a helpful link.
    Mk6 LED Taillights
  5. #1155
    Jul 2013
    Quote Originally Posted by Vexrz View Post
    Thanks!
    Same problem here, maybe a group buy could be next step. I had a look at some replicas on the internet, there is a good brand out there but it is hit and miss in regards, to installation, they can have a huge gap under the light and I dont really want to risk it and I think Genuine is the best way to go if you are pretty anal about the little things.
  6. #1156
    Thanks!
    Quote Originally Posted by chalres321 View Post
    Volkswagen Has both VW and Hella LED tails. Hella is the lights OEM for VAG, so they're actually the exact same thing, just they have a Hella part number, and are a bit cheaper. AFAIK they only carry the cherry red Hella tails, where as you can get cherry and dark cherry vw parts.
    Unfortunately with the dollar at where it is at the moment (and that it will stay around the same, if not drop a bit, since it's been overvalued for a while, see the RBA's minutes for the past 2 years lol), that's just how much you'll pay, at the moment.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  7. #1157
    Nov 2009
    Quote Originally Posted by moda View Post
    Exactly. I (like many in this thread) bought my tails from a German VW dealer, and the price back then - which is pretty much as keen as anyone in this thread has achieved - was still around $850 with today's exchange rate.
  8. #1158
  9. #1159
    Oct 2014
    Would you be able to comment on the quality of these Replicas or the Company itself?
  10. #1160
    Feb 2014
    Jupiter
    Just installed these the other day. Depo LED's. Got them for $350 delivered! The fit is pretty much spot on. I did have to fiddle around quite a bit to get them to sit right. The only minor issue I had (and it is very minor) was a very small dag on the corner which I just filed off. No coding etc required so an easy plug a play install.
    Ignore that the left side isn't illuminated.... It's just the camera not able to pick it up for some reason?
    But all in all I'm really happy.
