Page 99 of 118 FirstFirst ... 4989979899100101109 ... LastLast
Results 981 to 990 of 1178
Thread: Mk6 LED Taillights
  1. #981
    Central VIC
    Quote Originally Posted by Sawbin View Post
    Hey guys,
    Has anyone else had their DRLs stop working after coding the r tails? Got the coding done last weekend and have notice that my DRLs are no longer on. According to the lights and vision section they are on. Should I manually turn them off then on? Yet to try but will later today. Cheers
    I have same issue for my 12.5 GTI- dealer fitted R tails and no DRL's (halogens)- took back to dealer last week and they advised no solution, i.e cant have DRL's if have R tails! Its hard to follow the link Adam, too much info. Can anyone summarise the coding solution?
  2. #982
    Nov 2009
    Quote Originally Posted by andrew7 View Post
    Mate, that one post is really not that difficult to read. However if you need it paraphrased:
    Quote Originally Posted by AdamD View Post
    So, I checked my car, and yep, it was affected. Mine's a March 2010 build GTI with halogens, and I had coded byte 18 to 04 (00000100). The symptoms of this problem are:
    • The DRLs are not functional, and cannot be enabled or disabled according to the procedure in the manual.
    <snip>
    If you have a GTI built after week 45 2009 and with halogen headlights, I would try byte 18 = 15 (00010101) first.
    My car (MY10, halogens, R Tails) has fully-functional DRLs now with the correct coding for my car.
  3. #983
    Central VIC
    Thanks Adam, back to the dealer for a fix!
  4. #984
    Perth, WA
    Thanks Adam. Let's hope it works for my MY11
    2011 MkVI Golf GTI Reflex Silver DSG MDI Bluetooth RVC 18'' Detroits R Tails
  5. #985
    Perth, WA
    Just went back to mechanic to get the code changed but vcds wouldnt allow us to alter byte 18. Only could choose from dropdown box. Have the bulb out error back up on dash for now until i find a fix. Any ideas? 15 is what it needs to be! Very frustrating
  6. #986
    Apr 2009
    We went through this a few pages back mate. Look a the post on this page that shows the VCDS screen. http://www.vwwatercooled.org.au/foru...-40280-88.html
    You will see that the yellow figures in the top line are the same as the green ones that are in pairs in line 2. Underneath that you have the drop down box that doesn't contain the code 15 that you need.
    What you need to do is count across in the top line until you get to the equivalent figures for byte 18 in the second line ( in this case "04") and put your cursor after the 04. Backspace twice and enter 15 instead of 04. Click exit and Do It!!
    Car will now be coded to 15 see pic below to explain further.
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
  7. #987
    Perth, WA
    Thanks Ozram! Back to mechanic I go again. I wish he was closer.
  8. #988
    Nov 2009
    Quote Originally Posted by Ozram View Post
    Great post Stu!
    Sawbin, you can also override the dropdown and manually enter a value via the LCode 2 window. It's a pity that VCDS isn't overly friendly in the coding department... needing to count bytes across etc.
  9. #989
    Dec 2008
    Perth, WA
    Guys,
    I just installed the tail lights on my MY12 GTD, and they are just killing me!
    I got them in easily enough, but the coding of them really seems to be giving me trouble.
    I've tried coding the lights to HEX 15, 21, 22 and 1F and whatever I do, they won't work.
    The reverse light will light up the inner left hand tail light (red), and the indicators will make the outer LED lights (red) blink. Nothing will make the indicators (yellow) blink and the reverse lights come (both) come on sometimes when the sidelights are on... Something is really screwy!
    I can see you guys have been around these for a while so I would deeply appreciate any assistance you can provide. I'm at my wits end.
    Cheers!
    Edit: Apologies I forgot to mention, I've got a MY12 GTD with standard Halogens.
    Please help guys, this is really p*ssing me off. Thanks.
  10. #990
    Dec 2008
    Perth, WA
    Figured it out, son of a B****!!!
    The wiring adapters provided were wired up BACKWARDS!..
    The earth wire and the indicator wires were back to front!.. No wonder nothing was working....
    My good old multimeter once again saved the day!
    Coded byte 18 to Hex 15, all good including the DRLs....
    Beauty!
