Page 75 of 118 FirstFirst ... 2565737475767785 ... LastLast
Results 741 to 750 of 1178
Thread: Mk6 LED Taillights
  1. #741
    Nov 2009
    Hills District, Sydney, NSW
    If the screw is stuffed you may have to drill it out, if you go to the hardwarestore you can buy a drill bit specifically to do this. just pick up some new screws while you are at it
    How to Extract Stuck Screws.
    Screw or Bolt Extractor - How to Remove a Broken Screw
  2. #742
    Adelaide hills, SA
    The above is not much help to Koz, also be careful when you use these so called screw extractors, because usually people brake them in the bolt they try to remove and then it's more difficult to drill it out (the extractors are harder than the drill bits and therefor also more brittle).
    ---------- Post added at 07:48 AM ---------- Previous post was at 07:19 AM ----------
    to Koz there are businesses that specialize in removing broken bolts, they come to you. It's maybe a good option to consider.
  3. #743
    Dec 2006
    Kilsyth, VIC
    There is always Golf Loon's stuck bolt removal technique
    http://www.vwwatercooled.org.au/foru...vr6-10618.html
    ...although maybe it's not an option in your case
  4. #744
    Jun 2007
    Brunswick, Victoria
    Hey guys,
    Thanks for the input, Im getting a guy from my work to help me. Stay tuned for an update tonight, I think some might have a chuckle with part of the update.
    ---------- Post added 04-12-2011 at 08:07 PM ---------- Previous post was 03-12-2011 at 09:56 AM ----------
    So here is the update as promised.
    An older guy who I work with is really handy so I thought I'd get him to try and help - lucky I did. In regards to me not getting the white screw to undo so I could take out the large light and see if needed to be realigned, the problem was I was turning it the wrong way!!! What a ****head.
    Once I got the tail light off I noticed that the taillight come with one bent pronge in its adapter hence why it was working. He straightened that out for me then we plugged it back up and it was good to go. The on to the inner tail light which I thought had been threaded - he put WD40 on it we left it a few hours then he used his ratchet set and it come off as easy as can be.
    I can now say I have a full set of working R Tails on my car. Now all I need is to find someone with VCDS to help me code it.
    Koz
    Current - MY12 MK6 GTI, CW, Detriots, dark tint, APR Stage 1, blacked out grille, LED tails, Euro plates, suspension "tweaked", VCDS tweaks
    "The Ex" Black MY08 POLO GTI - APR,Coilovers,5% tint,stubby antenna, rear sway bar
  5. #745
    May 2011
    Box Hill, VIC
    Hi everyone, first i like to thank ozram for the contact and everything regarding the LED tailights.
    As i'm getting the lights next week, i need to start looking for anyone with VCDS or vagcom (sorry for my ignorance) and help me code whatever is needed for the tail lights. I live in Melbourne eastern suburbs (box HIll). Can anyone offer their assistance?
  6. #746
    Showing some pics of my recently installed cherry reds.
    Many thanks to Ozram for his assistance.
    ORIGINALS - OFF
    ORIGINALS - ON
    CHERRIES - OFF
    CHERRIES - ON
    Images hosted by Imageshack.
  7. #747
    Apr 2010
    Thanks for the pics - any chance of getting some day-time ones for better comparison?
    Ryan
  8. #748
    Jan 2010
    For people that lives in the east... Please call up audvolks... In Clayton the contact is Raymond... He's really helpful... And did my car today. He should know how to change it for u in matter of seconds, since we spent couple of hours today. I really appreciate his help. For ppl that wanna vagcom for halogen... The 18th byte value is originally 00, u need to change to 15!!!!!, change to make sure it's 15. U can also set to 04, as suggested by the dealer in germany(ozrams contact)... But the Parker's dot work. After code change, ensure all lights working.
  9. #749
    Apr 2009
    Quote Originally Posted by alphabeatsco View Post
    Not strictly true. It all depends on the year model of your vehicle. Actually it is totally reliant on what version your central electrics controller is. For instance, my 2009 halogen was coded at 4. Subsequent coding on newer vehicles has been 15, 22 or 45. The MY12 GTI I recently coded was back at 4 again. The paperwork you receive from my contact is a guide to the probable coding, dependent on your controller revision.
    Its important to check all your lights work correctly after coding. You can't really stuff anything up by trying different codes, I've gone through two or three sometimes to get the correct one. I'd still advise that you write down your original long coding setting before you begin.
    For more info on this see AdamD's excellent post here
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
  10. #750
    Jan 2010
    yes, that's right. obviously depends on your Central eletrics controller. thanks for clearing that up.
