Page 19 of 118 FirstFirst ... 917181920212969 ... LastLast
Results 181 to 190 of 1178
Thread: Mk6 LED Taillights
  1. #181
    Has anyone confirmed if Volkspower in VIC are able to code the car to get rid of the bulb out warning? I have emailed them a couple of days ago to see if they could, and I am still yet to get a reply.
  2. #182
    Jul 2010
    Bulleen, Victoria
    I am very happy to see that VW dealerships here in Australia are going to start doing LED lights for the GTIs.... If I can get my dealer to fit them, I will pay the extra cash to take away the risk and hassels of doing it all myself.... I suppose they would be able to fix the warning lights as well.
    I read something on the UK forum (I think) that GTIs being built now dont have the warning issue as the lights are plug and play... Has anyone heard this?
    2010 Golf MKVI MY11 GTI - Reflex Silver - 5dr DSG - Leather - Electric Seat - Sunroof - Sat Nav - 18" Vancouver Wheels - MY11 Bluetooth - Full Tint - 'R' LED Tail lights
  3. #183
    Apr 2010
    Yeah, my dealer offer to fit the LED lights aswell, but be prepared to pay $1400++ all up. It is a lot money tho =( For me it is really not worthed considering the installation guide from Ozram is fairly easy.
    MK6 Golf GTI MT|3D|CW|MDI|RNS 510|18" VMR V710 wheels - Sold~
    Mercedes B200 - Sport Pack|Night Pack|Command Pack|Vision Pack|
  4. #184
    Nov 2009
    Quote Originally Posted by mr fox View Post
    Gents can anyone post a picture of the gap pls....or is it an adjustment needed to align the tail lights?.....also is it something to worry about ie water entering?......
    Not exactly sure of the gap to which you're referring. I assume this is in response to Ozram's comment that his tails seem to leave a small (1-2mm gap) beneath the lights?
    Here's a 12MP version of one of the images I posted earlier: Golf R tail close-up 12MP (1.5 MB)
    Admittedly the fit isn't 100% perfect, but the tails aren't wonky and the gaps are I'm sure within standard manufacturing tolerances. If I was super fussy I might loosen mine off a little and fiddle with the fitment. But I'm okay with them as-is.
  5. #185
    Jun 2009
    Quote Originally Posted by AdamD View Post
    Hi Adam,
    Have you tried running water over the lights to see if it allows any leakages into the car?
    When i fitted my hella lights to the Tiguan i ran water over the car for a few minutes (also washed it) to see if they would let any water in as it might not be covered by warranty then.
    No leaks occured but mine fitted flush like the OEM ones did.
    I would check just to make sure.
  6. #186
    Nov 2009
    Quote Originally Posted by team_v View Post
    Hi Adam,
    Thanks team_v - that's a good idea; I will give the lights some sustained water pressure on the weekend. However, I'm confident there won't be any issues. For a start the fit is almost identical to stock (once again, it's an OEM part so the only question comes down to whether they've been installed correctly).
    But more importantly, the tails have been designed so that (I believe) it's okay if small amounts of water actually seep in behind the tail lights themselves (eg through the small gap above the outer tails in the water channel around the rim of the hatchback). The backing of the tails is all sealed plastic, with no exposed wiring, and the only opening between the tails and the interior of the car is a small rectangular area around which the tails have some substantial soft rubber sealing. The amount of tightening that goes into fitting the tails - those seals should keep just about anything out.
    Perhaps the next person who installs tails would like to take photos of the rear of the parts, for illustration purposes? Failing that, I can take some pics of my original tails, which look the same from behind.
  7. #187
    Oct 2009
    My fitment is the same as the picture. I'm just being ultra ultra ultra fussy!! So I'll fiddle with mine on Saturday.
    But as you note below these are the Golf R Tail Lights (came in VW parts boxes for me - Ozrams contact is a VW dealership in Germany) with instructions for the re-code. If you were to pull of your lights (original) and re-fit these you'll find some minor adjustments will need to occur just to line everything up perfectly.
    Now for the coding
  8. #188
    ok everyone, i've received a few msgs about this so thought i'd find the actual quote and give some accurate details.
    parts you will be buying are:
    1. VW-5k0945095L at $273.75
    2. VW-5k0945096L at $273.75
    labour will be:
    1. VW-5k0945093Q at $262.35
    2. VW-5k0945094Q at $262.35
    This is a total cost of $1072.20 + GST.
    Try and use your VW discount key ring for 7% off this price.
    hope this helps you guys.
  9. #189
    Feb 2009
    Quote Originally Posted by elwin View Post
    labour will be:
    That cost of the parts are quite reasonable, hardly worth getting them from overseas now. Definitely a DIY job as it's not worth paying the same amount in labor IMO.
    Do you need any other adapters or repair wires etc with the lights from the dealer or is it just a coding exercise?
    Cheers,
  10. #190
    Apr 2009
    labour will be:
    That is wrong. Refer post #129 in this thread http://www.vwwatercooled.org.au/f112...-40280-13.html
    They are just the actual part numbers for the 4 lights. There is no labour in there. And there is no mention of adapter cables that *are* required.
    $1072 + adapter cables + GST local v around $780 landed. I know which ones I'd get
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
