Originally Posted by
Hail
Pretty pumped, my LED lights are now on order
Has anyone sorted out the coding yet?
Hi Hail,
I coded mine today as per Ozrams post on byte 18 changed the default code of 00 to 04.
It's pretty easy, you just go to the binary code and enter 00000100 in place of 00000000 and the default "00" changes to "04"
This has eliminated all the fault codes but I'm yet to check if the bulb out still operates because I forgot to do it after the code change and haven't got access to VCDS atm (the bulb out indicator no longer comes on at start up - not that I noticed if it used to anyway but it's been posted somewhere as a potential issue)
My Gti build Feb 2010 but from what I can gather code 04 works on older build dates too.
Thanks heaps for all your help Ozram, I'm glad you got them up and running and they look awesome !
cheers
Mini Cooper S Chilli- when I can pry the keys
Carbon Steel GTi 19" BE by Breyton,LED tail lights, NEW 8" Nav !
Facelift Daytona Grey A5 Sportback, S-line 19" Titanium Rotors
