Page 105 of 118 FirstFirst ... 55595103104105106107115 ... LastLast
Results 1,041 to 1,050 of 1178
Thread: Mk6 LED Taillights
  1. #1041
    Jun 2012
    Melbourne,VIC
    Hi all
    I'm very keen to get the R lights for my 118TSI, build date JAN 09.
    I noted somewhere in the early pages of this thread that it said LEDs are not supported pre June 09 however i'm just a little confused...
    Referring AdamD's post #270 in this thread....
    Build date: Prior to 2009
    LEDs not supported
    Build date: 2009, prior to week 22
    Central Electrics Revision*: 03xx
    Headlights: Halogen or Bi-Xenon
    - Coding (hex): 4
    - Coding (binary): 00000100
    Being that mine is Jan 09, i believe it falls in bucket 2...so my question is, has anyone installed the LED tails and coded a Pre June 09 car?(going by above, it looks like it's possible)
    Question 2, anyone in Melb willing to complete the coding for me?
    Thanks!!!
    09 Golf 118TSI DSG
    White
    Adaptive Chassis Control
  2. #1042
    Nov 2009
    Quote Originally Posted by VeeDub23 View Post
    You may be in luck, and then again you may not.
    I'm not aware of anyone who's fitted the LEDs to such an early build car. It all comes down to whether your Central Electrics module supports the LEDs (and the ability to not throw a code when they draw less current than regular incandescent bulbs) or not.
    Ozram fitted the LEDs to his old 118TSI; I'm not sure of the build date of his car, but I seem to recall his was a July build and had the 0537/0541 revision. The only reason the coding summary post shows a coding option for cars pre- week 22 2009 is because the documentation I received with my LEDs suggested it, but I can't confirm it'll work - and I have read information on other sites suggesting it won't.
    Aside: I'm also not 100% sure of the coding for the 0537/0541 revision... I have it listed as 15, but maybe it's 4. Ozram, can you confirm the coding you settled on for your 118?
  3. #1043
    Jun 2012
    Melbourne,VIC
    Thanks AdamD
    I do note this from car systems.pl website
    For cars made before 2010 - new BCM is required
    Excuse my ignorance, but what is BCM and can it be self installed?
    09 Golf 118TSI DSG
    White
  4. #1044
    Nov 2009
    BCM is the old name for the Central Electrics Module (CEM); it stands for Body Control Module. CEM is responsible for lights, entertainment, and a whole host of other electronics.
    It's a physical controller; I have a feeling it's located underneath the dash up above the pedals on a Mk6. Yes, it is changeable, but I don't know of anyone in Australia who's done it. It wouldn't be cheap I suspect.
  5. #1045
    Jun 2012
    Melbourne,VIC
    Oh well!!
    Interesting that it says cars prior to 2010 need new bcm however Ozram converted his simply by recoding?!
  6. #1046
    Nov 2009
    Yes. You'll see from the coding post that it specifies a Central Electrics revision that's applicable to the coding - that's the piece of information you need, as opposed to the build date. The coding post tells you how to find this (via a VCDS scan), and it's that number that will tell you if we know whether your module can be coded for the tail lights, or whether it's an unknown (early) version.
  7. #1047
    Aug 2011
    Melbourne, Victoria
    Quote Originally Posted by AdamD View Post
    It's easily changed and requires re-coding based on original module for it to function properly. It's no harder to change than the CAN Gateway.
  8. #1048
    Nov 2009
    Quote Originally Posted by mythik View Post
    Yeah, not difficult to access, or code necessarily. But how much to get one?
  9. #1049
    Aug 2011
    Melbourne, Victoria
    They're around 200 Euro from CarSystems.
  10. #1050
    Apr 2009
    Yeah coding was "4" Adam. My car was June 09 build and I'm sure I read on a UK site that they couldn't get the LED's to work on vehicles built before May of that year. A new CECM from carsystems would definitely allow you to run LED's. I know of people changing them so they can convert to Xenon LED headlights.
    VeeDub23, I might know someone who is selling their old CECM which is from a 2011 GTI. It may fit?? I'll enquire for you.
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
