Results 1 to 4 of 4
Thread: Mk6 GTI Window issues.
    Hi all. I know this problem would have been discussed many times over the years but I can't seem to find a search button on this forum in Tapatalk, so a link would be much appreciated.
    Anyway, a friend of mine has had her drivers window stuck in the 'up' position for quite some time (maybe a year) and she goes through a card-operated parking station twice a day, so I can see she is a tad upset with her hubby who has put her complaint on the back burner.
    Question, what goes wrong and does it usually require a new complete mechanism/actuator? Is it the cable that fails? I've asked her to text a pic of the VIN so I can price one at the stealer.
    Suggestions? Hassles/tips to replace said unit?
    Thanks in advance.
    "You don't know what you don't know"
    Cheers dave
    Get a scan of the car.
    Door control module should give you an idea of what the fault is ie a switch problem or window regulator.
    Then replace said part. Both easy to do, just remove the inner door card first.
    Thanks. I have a Ross Tech but wasn't sure if it would pin point the issue or just indicate a fault.
    A distance of 800kms between us also posses an issue in diagnosis but they do visit every month or two. Mk6 GTI Window issues.
    Cheers dave
    Jul 2010
    Bit late to the topic...
    Same thing happened to me, I replaced the drivers door power window switches as one part. I just bought a new one via China on eBay like this OE Chrome Master Window Power Switch For VW Golf Gti Jetta MK5 MK6 Passat Rabbit | eBay
    It's a small amount of mucking around to pop the door card enough to install it, say 30 mins and a few torx screws and trim to pull, but worth it.
