Originally Posted by
Bug_racer
The leaking water pump on TSI engines is fairly common , as is the Carbon build up in almost all Direct injection engines . Everyone seems to have the same way of thinking that this is a problem , and if you have a problem then you search for a solution . Question then is what are you trying to achieve . No more Carbon build up on the intake ? But what about the injectors ?? A catch can isnt going to stop this from happening no matter what you do , Carbon is a by-product of combustion so unless you run the injectors in the manifold and run a catch can its not going to solve the "issue" . Alternatively you can treat it like a maintenance item and once in a while remove the manifold , clean the intake and clean flow the injectors . Changing the PCV will also help as the PCV gets blocked up with Carbon as well over time . I dont recommend catch cans as Ive seen quite a few rocker covers fail due to a one way valve not being able to operate correctly which then causes poor idling and dumps oil in the re/circ type catch cans .
Now to clean the intake takes more than just a few days , on average it takes me a week to remove all of the carbon on the intake / dividers , clean the manifold and clean and flow the injectors ( I had a special DI machine built for this purpose) . The hardest part is polishing the valves once all the carbon is removed to get the original shiny finish which slows the carbon build up down . I do this on my own car just before I race . Also the prices the OP mentioned is how much I charge for parts/labour for the work .
