Corey, can you verify if the TPI 2021062/7 includes the CCZB variants aswell?
according to the TPI info i have, it only states "CBFA, CCTA" variants only.
that being the case, why is VW Aus refusing to fix the rattle in the octavia rs (CCZA), while fixing the GTi (CCZB) no questions asked!?!?!
i don't understand. both engines are exactly the same (mechanically). its only software (ecu) that is different.
the americans use a different (mechanically) variant of the EA888 engine for their GTIs, hence they have CCTA and CBFA, which the TPI relates to.
NA (north america) MK5/MK6 2.0 TSI Engine
- CCTA
- CBFA
CCT and CBF denote the engine's mechanical structure. i.e. secondary injection (CBF) vs non secondary injection (CCT). A, the 4th letter, denotes the power output for the calibration, i.e both rated in the us for 207ft-lb/200hp.
ROW (rest of the world) MK6 and A3 2.0 TSI Engines
- CCZA - A3
- CCZB - MK6
CCZ denotes the european mechanical structure. A and B denote a software calibration change for different power levels.
A has 200hp, B has 210hp.
- TSI Trans CBFA NA 2.0 TSI 200 HP
- TSI Trans CCTA NA 2.0 TSI 200 HP
- TSI Trans CCZA ROW 2.0 TSI 147kW (200 PS), 280Nm
- TSI Trans CCZB ROW 2.0 TSI 154kW (210 PS), 280Nm
if vw aus told me (and skoda aus) that they won't do it because the TPI only applies to the CCTA and CBFA variants, i'd understand - their EA888 engine structure is actually different to what we have here.
however vw aus are fixing the GTIs here under warranty, despite them, also having a different variant (CCZB) to the TPI!
why can't they (vw) apply the fix to the CCZB too?
the tpi issued is based on the engine variant - not on the "brand" of the car (vw, audi, skoda, seat - all under VWaG).
does vw aus understand this?!?!
no good/luck i guess if the vw techo firmly believes the RS and the GTI have different engines!! if only they knew!
makes me also question why use vw service centre to service the car if they don't know the differences? i'm better of taking it to audi as their A3s use the exact same CCZA engine. i wonder if they have a tpi for the CCZA? hmm......
then again, based on vw's treatment, what luck do i have with audi doing it under warranty for my skoda, let alone touch it!!
