Hoping to find some feedback from the more tech savvy mechanical guys on here.
My 2010 model Mk6 GTI rattles on cold startups. Pretty much every cold start will rattle, with only the odd exception that it wont. Sometimes on a warm startup (eg left parked for an hour) it will also rattle, but only sometimes. Hot starts it basically never rattles.
Car has 69,000km on it and the engine is perfect apart from this rattle.
I've had the timing chain tensioner replaced last year - no difference. I removed the N205 valve and cleaned it - no difference. Engine is full of Liqui Moly VW504-507 oil and last oil change was only 5,000km ago. No errors of any sort on VCDS scan.
After more research into this noise, im now thinking it could possibly be my starter motor hanging up on the flywheel for a second or so after starting.
Do you think this is a possible culprit? I jumped under the car last night to check the OEM starter motor, and its a Valeo unit with part number 02M 911 023M.
I have just recently rung my local auto electrician who said they can source a new replacement Valeo starter motor for $450 overnight from Queensland. ECS sells them for around $400 but then you have the conversion rate plus shipping, so it makes sense to purchase locally.
I am happy to buy a new starter motor if it gets rid of this damn engine rattle - any feedback from the mechanics on here as to whether this is realistic would be appreciated.
Below is a photo of my starter motor. Is this the stock item? The listing on ECS shows a slightly different part number, so i assume the stater motor has been revised at some stage? 403 Forbidden
