no, they just come on.
Quick question in regards to the Auto lights, is there an illumination indicator/warning buzzer in the dash which tells you that the Auto lights have switched on or off when in low light conditions, such as going through a tunnel etc.
mtj007 is right. when in auto and lights are not on the switch "auto" picture should be green.... when the lights become active the picture goes red.
it will be obvious when they are functioning as your dash lights will come on also. if its dark enough to activate your lights you will definitely see them on.
not sure if they are harder to see if the dash lights are white. my jetta dash is blue so they are easy to tell if they are on.
1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
I asked similar for my MkV R32. The changes to the sw ind and the dash lights coming on are not obvious.
In some Audis there is a low beam ind in the cluster that can be programmed on.
I have not been able to find it on the MkV. Maybe the MkIV has it too? and needsVAgCom to activate? Good luck
Bazzle
Prev 2008 R32 3 door DSG.
Prev 2010 S3 Sportback Stronic.
Now Lexus IS350 F Sport
You can increase the brightness of your dash lights!
Hi all, I've had my 118TSI (my first Golf) for the past 2 months and it's been going great so far!
I have recently noticed an issue with the auto light function which I'm not sure is normal or not. When the lights are in auto mode and I'm driving in the evening the headlights are on as normal however the left foglight is on as well but the right foglight is off!
When I switch over to headlight mode, the headlights are on and both foglights are off. I then pull out the switch and both foglights come on as expected, hence there doesn't appear to be anything wrong with the right foglight globe.
So is the left foglight being on but not the right foglight in auto mode normal? Thanks
Is the steering wheel turned left or the left indicator on when this happens?
I think the Mk VIs with foglights also use them as cornering lights, I'm not sure under what circumstances this function works but it sounds like maybe that's what's going on with your car
I was waiting at an intersection yesterday and a Ford came around the corner and I noticed one of the foglights was on, it went off at the same time as the indicator.
My dad's Mk VI doesn't have foglights so I can't check but I've seen it mentioned in a couple of reviews.
Edit: In this review it says they light up with the steering wheel turning, not the indicator being turned on. http://www.ausmotive.com/2009/02/01/...vi-14-tsi.html
