Results 1 to 2 of 2
Thread: Mk6 golf wagon 1.6 tdi DSG issues
    Oct 2022
    Picton,NSW
    I picked up a wagon on the weekend, the car drives then gets the flashing gear selector. Got the error codes as below.
    CAYC engine and NTS DSG gearbox, from initial readings on the forum, I’m guessing the mechatronic unit is stuffed
    my question is can I get any DSG gearbox and fit? Or do I need to find one that is NTS? The car is complianced as built 1/2013
    thanks for any responses.
    ============1==============
    U0101
    Raw code: C101
    ECU: Engine control unit
    Status: Confirmed
    OBDII: Data bus, transmission control module (TCM) - no communication
    ============2==============
    6088
    Raw code: 0017C8
    Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
    ============3==============
    1315
    Raw code: 0523
    ECU: 19. CAN Gateway
    Status: Test conditions are met, Validated and stored in non volatile memory
    Volkswagen: Gearbox control unit; Transmission control unit
    ============4==============
    5636
    Raw code: 1604
    ECU: 02. Transmission control unit[Archive (inactive)]
    Status: Validated and stored in non volatile memory
    Volkswagen: B1291F5: Multimedia system control head
    Button for telephone "TEL"
    Volkswagen: Control unit faulty
    ============5==============
    6228
    Raw code: 1854
    Volkswagen: Data bus drive defective
    ============6==============
    1830
    Raw code: 0726
    Volkswagen: U147300: External sound amplifier
    no communication
    Volkswagen: Fog lamp; Lamps for rear fog lights; Speed ​​signal from engine control unit implausible signal
    ============7==============
    1315
    Raw code: 0523
    ECU: 03. ABS control unit
    Status: Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request
    ============8==============
    6088
    Raw code: 0017C8
    ECU: 01. Engine control unit
    ============9==============
    1315
    Raw code: 0523
    ECU: 09. Onboard supply control unit
    Sep 2024
    Brisbane Queensland
    Were you able to sort this out?
    I have the same issueand cannot find a NTS coded gearbox.
    2012 1.6 tdi diesel wagon
