Originally Posted by
logger
Is is possible to buy a non remote (dumb) key for current VWs? Not keen on leaving my car keys in the wheel well when I go surfing. The 2 provided remote keys will drown if i take them swimming. So I reckon I need a plain old metal key. is there such a beast?
If you want to hide your normal remote in the car and lock it with a "dead" key then it is very simple to just buy a blank plain key without an immobiliser chip. Lots of good locksmiths can do a computer controlled VW key cut, some will even have a VAG blank available. If not, blanks are readily available on line.
If you really want a key that will operate your engine that his a whole new (and more expensive) ball game. The only place I've found that can supply an immobiliser chip that works in modern VAG vehicles is the VAG dealer, and you also have to get the ECU programmed to recognise the new key. The immobiliser chip is totally waterproof (but not the remotes).
Remember to wipe off the salt water before putting it in the lock, otherwise it will corrode the pins/wafers.
