Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: MK6 Golf dash rattle doing my head in.....
    Hmm after doing some more dismantling tonight i worked my way up to the roof lining and removed the vanity lights under the sun visors. Each light housing has a metal spring clip which helps hold the light in place. The clips are loose and when i shake the housings i can make the clips rattle and they sound very similar to the rattle i am getting.
    Some adhesive silicone and temporary tape has been used to secure the spring clips...could these be the rattle perhaps. I'll find out soon enough.
    May 2010
    Something else to check if the vanity lights aren't it is the bonnet hinges. I had this problem on a Subaru I had where the hinge was loose. It sounded like it was the dash but was just echoing through.
    GTI | Carbon | Man | 5 door | Leather | 18" Detroit | Bluetooth | MDI | Bi-Xenon
    Apr 2011
    Melbourne, VIC
    Had the same thing exactly. You would never think this would be the cause.
    Was the metal buckle end of the stuff they tie parcels with That blue nylon tape.
    Where was it In the rear of the bonnet between the frame and the top Had to take the sound deadening out and hook it out with a bit of wire.
    Was annoying as it swooshed across when going around a corner .
    Another place for you to look
    Damn, that sounds complicated. I might get Koji to look for it as we go around Lakeside this Sunday!
    Dec 2007
    GLENHUNTLEY,VICTORIA
    Rattles drove me mad and forced me away from the VW brand.
    Pacific Paradise QLD
    Quote Originally Posted by anthony View Post
    Rest assured that not only VW have rattles, computer problems and other assorted minor complaints
