I was referring to not installing it on a 3G/3GS .
Unless you look at the phone using a magnifying glass I really don't think it makes a difference, just like the difference between lossless and 320Kbps MP3 in the car sure in theory lossless is better but in the car it makes no difference.
There is a lot more to a phone and features like true multi-tasking, not being locked in to one provider who locks everything down, being forced to use itunes, no flash support, no expansion of memory, no user replaceable parts like batteries, an open operating system that others can use, variety of different hardware types and so on and so forth are all factors that should be looked at not just buying an iturd and joining the other sheep.
website: www.my-gti.com
Seems poor old sharkablue fired up this thread to seek info about BT options with a iPhone 4 and BT in a new VW. He is not really getting much help. Just turning into another pissing match. I would offer to help but I only have access to an iPhone to which I am about to add ios4. But I do not have a BT equipped Golf 6. Hopefully someone else will pop up soon who has both ios4 and BT in a VW who can report back something useful for you.
You can hear the difference in the car, try comparing a CD to the sound from the SD slot.
Some good points there so will be considering all the options out there next time i'm due for a phone.
Jailbreaking helps unlock a lot of the functionality, and a fair bit of development behind it. Amazing that they are able to keep it fairly simple as well.. (compared to the old days when i was customising HTC's with Windows OS).
Whatever phone you get they are boring after a while once the novelty has worn off. At least a lot of the games and apps keep you amused a bit on the iphones (but wouldn't buy any).
If you re-read the post he was talking about 'iPhone 4.0 Software update', not using an 'iphone4'.
I offered him the advice which was not to do the OS4 update till apple come out with a fix for the bluetooth issue. 3G and 3GS work perfectly fine with the VW Skoda kit.
Anyway best thing to do is wait and select a phone and BT kit you know work together.
Lets keep the conversation on topic please. Mentions of Google/Android or any other phone manufacturer are not required as this thread is specifically about the iPhone with VW Bluetooth. Cheers
I found this user here with a MK6 GTI with the VW Kit installed and it apparently works fine?
Print Page - iPhone 4.0 software fiscon issues
Can someone with an iPhone and Bluetooth in their MK6 Please confirm if you have issues with the new iOS4 update?
As I said I dont want to shell out $1500 for a bluetooth setup that does not work with my current phone.
MK6 GTI 3 Door - Candy White - DSG - Sunroof - 18" Detroit - ACC - PA - RC - MDI - BT - RNS510.
Hi,
I've updated to OS4 and have a Kufatec bluetooth setup with no issues at all. It also worked fine on the previous version of iphone OS - no difference. The Kufatec bluetooth setup was put in by my dealer as he said it was better than the Advanced bluetooth from VW. I only ordered the standard bluetooth, so pretty happy with what I ended up with.
MY10 Golf GTI - Candy White - DSG - 18" Detroits - Leather
I found some some links on the NEW MK11 9W7 Bluetooth kit here:
How soon before we are able to purchase the 9W7 Bluetooth upgrade and who will have it first?
The Bluetooth debate comes to an end! Hello 9W7! - TDIClub Forums
It seems the brand new Bluetooth setup is actually just as good, if not better then the 'Skoda Kit' (aka: 1Z0035 729 E).
I have asked my dealer if they could order and install this one for me, and they said they could not. However they were happy to order and install the Skoda kit for $1500.
Maverick after reading the threads I have posted regarding the new Bluetooth kit, what are your thoughts?
I dont know how the america and canada works, but all the people with the new 9W7 kit are they all have the sat nav installed and NO RCD 510's.
My GTI is coming with the stock standard RCD 510 not the RNS.
Maverick are you able to shed some light on this after reading those posts? because if this new kit is just as good as the Skoda kit, I may well ask Volkspower to order it in and install it? since my dealer said it cant be done?
