Page 15 of 17 FirstFirst ... 51314151617 LastLast
Results 141 to 150 of 168
Thread: The Mk6 Golf Battery Thread
  1. #141
    Erskineville, NSW
    Quote Originally Posted by Tobes_WIR35 View Post
    Call somewhere like Battery World and tell them your make and model. They'll know what will suit. They will probably give you the option of Varta, Yuasa and maybe others. The Varta will be about $400 or so, the Yuasa less than $200. They will both work but the Varta is a better battery. They have a different type of cells. I went for the Yuasa, thought I would give it a shot as I went through two Vartas in less than 4 years/84,000km and figured I couldn't do much worse than that with the Yuasa, however YMMV (literally).
    $400 for a Varta? Mine was $225 and the specifications were way in excess of the OEM unit. Bosch are similar prices & just as good (possibly a better warranty).
    Yuasa are a good battery. I'd fit one in a New York minute.
  2. #142
    Feb 2014
    Central Vic
    Just remember, don't lift using the terminals.
  3. #143
    Erskineville, NSW
    Many of the Euro style batteries have inbuilt handles these days - very helpful.
  4. #144
    Feb 2014
    Central Vic
    We had a Honda Accord (in the extended family) with a Yuasa which lasted 10 years.
  5. #145
    Aug 2015
    Just changed the car battery last week, all of a sudden it just went dead overnight no warning signs at all.
    Not a bad run, just over 4 years old on the oem battery.
    Picked up a sealed super start battery from Lansvale for $150 and 10 mins to fit, cheaper than NRMA who wanted double the price.
  6. #146
    Sep 2010
    Southern Highlands NSW
    Hey fellas, looks like im up for a new battery..... Would like to try out the Bosch S5 what model do i need for a mk6 GTI and will it fit in the battery housing? Any help is highly appreciated
    Polo GTI
    T-Roc R
    Tiguan R
  7. #147
    Jun 2011
    Sunshine Coast, Queensland
    ALCO Calcium batteries are an excellent battery if you don't want to pony up for an AGM. Have two in the tractors, one driving a pump, another two in each car.
  8. #148
    May 2007
    Jimboomba. QLD
    Replacing the bettery
    Hi everyone.
    Apologies if this has been covered before, did a quick check and couldn't find the answers
    The battery on my 2010 golf is starting to struggle when starting on these cold mornings. It is the original battery. Since I have more than 6 years out of it, I guess a new one is on the cards.
    Question is.....once the battery has been replaced, what (if anything) needs to be reset? I am guessing the security on the radio for a start and do I need to take it to VW to do this?
    Thanks in advance
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
  9. #149
    Adelaide hills, SA
    Your radio will work and once you drive the fault for the steering and the traction control should also turn itself off, though maybe the airbag fault will need resetting with scanner.
  10. #150
    Jan 2012
    Did mine last year, nothing needed to be reset, just change it straight away. As in unplug the old one and plug in the new one. Yes lots of faults until you drive forward for about 10 metres.
    2015 Golf R. Lapiz Blue.
