Page 6 of 17 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 168
Thread: The Mk6 Golf Battery Thread
  1. #51
    May 2011
    Melbourne, Vic
    I guess so but I would check what it says about jump starting in the manual first.
    MY 12 Golf GTI
  2. #52
    Quote Originally Posted by magellan View Post
    Check the voltage with a multimeter? If it is down.
    Connect another car up with jumps leads and leave it idling a while, before you try starting. It'll put some juice in the dead battery before you try cranking it.
  3. #53
    Jun 2009
    Perth, WA
    Will do
    Sent from my SM-N9005 using Tapatalk
    2010 | Mk 6 | Golf GTI | DSG | black | 18" Detroit's | MDI
  4. #54
    Jun 2009
    Perth, WA
    Just got back no go. Multimeter read just under 12v. Connected to donor car at idle to fast idle then tried but same symptoms. Errors that show are airbag and brakes. Lights still have juice.
  5. #55
    Quote Originally Posted by MovieDude View Post
    Looks like a tow then unless you can find someone with VCDS to scan it.
  6. #56
    Jun 2009
    Perth, WA
    Yup tow it is
  7. #57
    Oct 2013
    Had all these same issues when my battery went caput in the R. Threw heaps of codes. And even showed voltage at the battery. Get a jump and leave it chargibg from the other car for a little while, thats what mine needed then it started and worked fine.
    this message brought to you by the tides and waves in a barnacle encrusted bottle sealed with a cork!
    MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
  8. #58
    Jun 2009
    Perth, WA
    Did you then replace it?
  9. #59
    Jun 2009
    Perth, WA
    I'm wondering if maybe I should cancel the tow and get a mobile battery service to come and replace the battery.
  10. #60
    Jun 2009
    Perth, WA
    But if the headlights work then it can't be the battery right.
