I guess so but I would check what it says about jump starting in the manual first.
MY 12 Golf GTI
Will do
Sent from my SM-N9005 using Tapatalk
2010 | Mk 6 | Golf GTI | DSG | black | 18" Detroit's | MDI
Just got back no go. Multimeter read just under 12v. Connected to donor car at idle to fast idle then tried but same symptoms. Errors that show are airbag and brakes. Lights still have juice.
Yup tow it is
Had all these same issues when my battery went caput in the R. Threw heaps of codes. And even showed voltage at the battery. Get a jump and leave it chargibg from the other car for a little while, thats what mine needed then it started and worked fine.
this message brought to you by the tides and waves in a barnacle encrusted bottle sealed with a cork!
MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
Did you then replace it?
I'm wondering if maybe I should cancel the tow and get a mobile battery service to come and replace the battery.
But if the headlights work then it can't be the battery right.
