Page 5 of 17 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 168
Thread: The Mk6 Golf Battery Thread
  1. #41
    Jan 2011
    Brisbane - QLD
    Quote Originally Posted by DonJuan View Post
    Battery World stores do MK6 GTI / R batteries for $179... Just saying
    Nat, nice pickup but these AGM's are quite expensive, think from memory they are easily double the price of standard replacement. How does the additional height go due to the fact the optimas don't have recessed terminals?
    Heightwise, the terminals height is the same.
    The Mk6 Golf Battery Thread-uploadfromtaptalk1396345063936-jpg
    Sent from my GT-I9300T using Tapatalk
    MINI Cooper S Clubman - FWD
  2. #42
    Jan 2012
    GTI mk6 battery
    Not quite gone yet but 3 years and 11 months old and it's been getting harder to start for the past 3 weeks and then today got the ticking noise that comes when it won't turn over. Twice I had the ESP Fault come up on the MDI, which after research appears when the battery is on it's way out. Had the battery tested today after it almost didn't start. 32% of battery life still charges fine and holds 12 volts but rather than 480 of something to start the car it has 260 of something. Off to VW on Saturday for a new Varta at $274. Rear sway bar will have to wait. Bummer.
    2015 Golf R. Lapiz Blue.
  3. #43
    Jan 2011
    Brisbane - QLD
    Quote Originally Posted by Reedy View Post
    Or u can get what i bought, Optima D35 (gel), for $15.95 more than the OEM Varta (calcium acid).
    Seller is in ebay (cluboutdoors), incl free delivery direct from Optima Australia.
  4. #44
    Apr 2011
    Melbourne, VIC
    Quote Originally Posted by tonymy01 View Post
    But very different battery technology. A couple of deep cycles on a standard battery will kill it, those are designed for deep cycle. With all the stuff the VW does with the engine off (combined with, say,a traffic/parking camera drawing power 24x7), it doesn't take many days to cycle the battery enough to drop it below cranking level. My R is only 2 years old, and i notice the battery has significantly reduced capacity. I often don't drive the car for between 3 days and two weeks. I typically have to put it on charge for a two week stint without driving.
    Yes, agree with the deep cycle but it's really only if you have a constant drain do you need the deep cycle. Even start stop technology will help kill a starting battery quicker due to the additional starts and not charging for long continuous periods. If people are adding aftermarket accessories which is going to drain the battery then they should also be looking at how many amps its drawing over x amount of time to correctly size the battery they need. In Nat's case, the amount of time is reduced but it will do less harm to the battery in using it.
    I guess it'd be interesting to hook the car up to a meter to see how many amps are constantly flowing through the car with it switched off...
  5. #45
    So consensus is either go Varta or Optima? Need a new battery in the TDI, have a 10% voucher for Batteryworld so figured i'd just go there. Probably get a Varta, since they seem to last a fair while. Will probably try and get as big a capacity/CCA as possible/that will fit.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  6. #46
    Jun 2009
    Perth, WA
    Mk 6 GTI won't start
    Left it for an hour in the car park middle of this afternoon, dry no rain and mild temperature. Went to start and I get just a relay sound. Centre display shows an ESP error. Electric windows work intermittently and requires ignition to go off then back on. On releasing ignition screen tells me to put DSG into P/N but it's locked and requires two dabs of the brake pedal to release it.
    I've arranged for a tow tomorrow morning but can anyone shed any light on what's gone wrong?
    2010 | Mk 6 | Golf GTI | DSG | black | 18" Detroit's | MDI
  7. #47
    Jan 2012
    ESP fault on my MDI came up when my battery was going flat. Not sure about the DSG as I'm manual.
    Ozzy
  8. #48
    May 2011
    Melbourne, Vic
    Are you still on the original battery? If so it sounds like you might need a new one
    MY 12 Golf GTI
  9. #49
    Jun 2009
    Perth, WA
    I think so
    Sent from my SM-N9005 using Tapatalk
  10. #50
    Jun 2009
    Perth, WA
    Is it worth a jump start?
