Results 1 to 10 of 619
Thread: The MK6 Fuel Consumption (Most / Least per Tank) Thread
Threaded View
  1. #9
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by epicmac View Post
    First tank in the GTD, 660 km so far with 125 km to go according to the car.
    I use the 'fuel log' android app to track consumption. No figures yet of course.
    Any update on this? I'd be interested to see how a non-GTi/R fares on consumption - no one else seems to be posting (apart from hentaiboy with his DSG issue - I wonder if the 118 update to stop the piston melting increases consumption too).
    I find that once the MFD shows range under 100km, the remaining range drops off far quicker than actual mileage which is a bit unnerving if you are in the country and pushing the range.
    Resident grumpy old fart
