Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: MK VI GTI Advice
    MK VI GTI Advice
    Hi All,
    I'm interested in getting myself a MK VI GTI Manual.
    I have read on this forum about the timing chain tensioner issue and want to ask the following:
    1. Is this a common problem? Or does it only effect some cars?
    2. Where is the best place to get this fixed in Melbourne?
    3. How much would it cost to repair (parts and labour)?
    And 1 more question:
    - Is there anything else I should look out for when inspecting one of these cars?
    Thanks in advance.
    Jan 2012
    Timing chain tensioner was only an issue for pre 12.5 mk6 GTI's. I had my 2010 GTI done including chain and guides for $2000, I think LucasR just did the tensioner for just under $1000. Besides that mate I had mine for 5 years and loved it. Only issue I had was intake manifolds, I had 3.
    2015 Golf R. Lapiz Blue.
    I had a number of quotes between $1,750 - $4,000 from both dealers and specialists.
    I'm looking at a GTI or a Focus ST. Each has it's strengths and weaknesses so I appreciate all responses on this forum.
    Nov 2009
    Quote Originally Posted by macchina View Post
    Just do what these guys did:
    MK VI GTI Advice-both-jpg
    FWIW I had three years with my Mk6 GTI and only had a water pump go early under warranty (I think nearly every one went through this) and that was pretty much it - best car I'd owned to that point, and perhaps still is.
    A post 2012 built GTI seems to be safest as it would have the latest tensioner but if buying pre 2012, just factor that cost in.
    As you may have noticed on the forum, not every single car with the pre 2012 gti models have had the tensioner go.
    Edit:
    Mk6 also has the wastegate rattle .. annoying but doesn't affect performance. There is a fix for it.
    RS
    R
    Jul 2011
    Aust
    Quote Originally Posted by Tuan View Post
    Edit:
    My Mark 6 09/2012 build and 01/13 delivered GTi had the rattle clip installed at factory.
    Quote Originally Posted by minke View Post
    And so it should be ! Cheap part to have been excluded from factory which caused quite a few unhappy MK6 GTI customers and countless threads on the annoying wastegate rattle.
    RS
    R
    Tuan - Can I ask why you went from a GTI to a Focus ST? And what are the major strengths and weaknesses of each?
    I've never had a GTI .. ?
    Lots of reviews comparing the two cars.
