Results 1 to 10 of 13
Thread: Missing Low Tyre Pressure Button
    Oct 2009
    Melbourne, Victoria
    A friend and I both picked up new cars in the past couple of weeks. Almost identical specs and both with a sports pack. His is a DSG, mine is manual. He has the low tyre pressure button in the button bank in the centre console. I don't have this button.
    Any ideas?
    Feb 2009
    Sydney, Australia
    Check in the glove box. I've heard that it may have moved to there.
    It's probably because with the latest Golf's there is so many options which could require a button in the centre console bank, that they've decided to just move the tire pressure button, which is rarely used, to the glove box.
    Oct 2009
    Melbourne, Victoria
    No, nothing in the glove box.
    Feb 2009
    Sydney, Australia
    Hmmm... I'd be asking the dealer then. It would either be in the glove box in the upper-right-hand corner, or on the centre console. I haven't heard of it being anywhere else.
    Aug 2009
    Melbourne, Vic
    One other very unlikely place to check is in the MFD menus. Given it is a button that you rarely need to press, there is no reason for it to be in reach. VW could just move it in there to the electronic menus. Apart from the missing switch the same ABS Controller & instrument WRNG light cluster is fitted to cars with and without the system activated.
    Oct 2009
    Melbourne, Victoria
    Gee that is what happens when you take a boy look! Found it in the corner of the glove box, but it doesn't do anything. It just seems to be a loose button. Kind of ironic, I think it was making the small rattle from that area of the car.
    Aug 2009
    Melbourne, Vic
    Glad you found it. It's not supposed to do anything when pressed so sounds like it is working fine. The manual should explain how to press it along with I think the ESP button for perhaps >5 sec to reset/calibrate the TPWS.
    Sep 2009
    you usually press it for about 2 seconds after which you should hear a beep to confirm that the new pressure has been accepted.
    Jetta MK6 147TSI DSG Reflex Silver
    Pondering: too many to list...
    Aug 2009
    Melbourne, Vic
    Nup, with this particular Warning system it is nothing to do with tyre pressure. The button resets something in the Antiskid module. I am sure someone else can explain.
    Sep 2009
    no doubt, though to normal people like myself it's just to tell us that if the pressure is low, you get a warning
