Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 64
Thread: Mirror dipping / Reverse mirror tilt
  1. #41
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by SilvrFoxX View Post
    You can.. either move the seat forward or tilt the seat forward .. problem soved
    Actually. That's something I agree with. I have the same issue with the drivers side mirror not adjusting enough.... although, for my particualr seat position, the issue is more that the outer edge of the drivers side mirror housing obscures too much and so there is a limit to the useful maximum adjustment available... but that's another issue
    Quote Originally Posted by redhot View Post
    When is VW going to give buyers folding ext mirrors and illuminate the ignition switch?
    The folding external mirrors is an option on many models overseas, but not here. So I don't think it's a pressing issue for them. Australia doesn't typically have thin alleys to traverse.... I don't know.
    As for the illumination of the ignition switch. I'd say that you'll get push button start before that...
  2. #42
    Jul 2011
    Slacks Creek QLD
    i still think its a matter of learning to reverse properly..
    90 TSI 1.4T
  3. #43
    Nov 2010
    Quote Originally Posted by Candyman View Post
    There is no option
    You select the left mirror whilst key is in the on position and stationary, move it down to the area you want to view and then turn key off and then every time you select reverse with the selector on the left mirror it will move down automatically
    When you drive off, move selector off left and it will return to normal
    That is how mine works on my R which doesn't have park assist
    MY12, DSG, leather. Otherwise base model
    Save yourself a couple of kilojoules of effort!
    After setting up your two preferred positions of the left mirror, you don't have to play around with the mirror selector every time you want to reverse/cease reversing - if you did, it would be incentive enough to learn to learn the width of your car! Mine was almost fully automatic. Oddly, the only time I had to muck around with the switch was when I had the mirror heaters on (the switch at 12 o'clock) - the mirror wouldn't drop until I turned the heat off. In any other position, the mirror would auto-drop in reverse and auto-correct when moving off. I assume everyone else has found the same?
    MY11 R, no park assist.
  4. #44
    Mar 2008
    Sunshine Coast
    Tried again this morning (at service dept)
    Same issue so perhaps something not right in my R ?
    They are looking into it now
    It isn't about learning the width of the car
    For me, it is just having a feature of the car work as expected. I may or may not use it from time to time.
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  5. #45
    Jun 2009
    Apologies, I know this question has been posted before but there seemed to be some uncertainty every time.
    Conclusion: The car needs to be fitted with parking sensors from the factory. For every model except the R park assist needs to be optioned.
    Quote Originally Posted by SMOK3Y View Post
    Okay we get it... Apparently two posts saying that you're an amazing parker wasn't enough and you felt the need for another. Here, have a lolly
  6. #46
    Jan 2008
    Lower North Shore
    Hmmm.
    I thought I had set the MFD within setup for dipping mirrors, anyway I know it works and I love it....
    LS
    In Carport. R
  7. #47
    Aug 2011
    Sandy Bay, tasmania
    my new passat 118 comes with front and rear park sensors as standard, but does not have the mirror dipping feature. Apparently it's only available in the V6 version.
  8. #48
    Jan 2008
    Lower North Shore
    I knew i hadn't made it up. If you go to the convenience menu on the MFD in the Golf R it is an option to tick called mirrors down. You can switch it on and off.
    LS.
    In Carport. R
  9. #49
    Nov 2010
    Quote Originally Posted by langers_sydney View Post
    LS.
    +1 i thought that was the case as well, i've got it as an option in my convenience menu as well.
    MY11 Reflex Silver Golf R DSG / Mitsubishi Evolution MR
  10. #50
    Jan 2008
    Lower North Shore
    Talk about tempt fate. I noticed on asaturday as I reversed that the mirror has now stopped dipping! Checked the MFD and the option is still ticked. Any ideas how to reset or reprogramme anyone?
    L_S
    In Carport. R
