Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 130
Thread: Media Device Interface - MDI & AUX Questions
    Apr 2009
    Hi,
    I' interested to know if it's worth getting the MDI with the standard stereo RDC310 in the MK6 ?
    I would like to know if can you control your ipod through the MDI on the RDC310.. Example skip songs on and so on...
    Or
    Are you better to stick with using the AUX input which comes standard with the car if you are sticking with the standard stereo ?
    or if I have bluetooth can I use A2DP stereo Bluetooth do u think you can use this to control via the stereo
    any help would be great.
    Mar 2009
    I have the ipod connector and its not the easiest thing to control. Good thing is that it charges it. The sound is crystal clear.
    Just some gripes as in when you play from your playlist, the stereo will not remember to start back on that playlist when you next plug it in. It does remember however if you play from the all songs list.
    Apr 2009
    In the mountains
    I'm wondering if the MDI can be fitted after the car has been delivered?
    Mar 2009
    Melb
    I read that a retrofit device has been made though not sure if its available here.
    http://www.my-gti.com/688/volkswagen...e-mdi-retrofit
    May 2009
    NSW
    A2DP stereo Bluetooth comes with the $700 Bluetooth I got mine last week..
    Jun 2009
    sydney,nsw
    Quote Originally Posted by mr gee View Post
    i got this installed by the dealer prior to delivery in my mkVI tdi103 with the standard RCD310 unit. haven't used it yet tho
    what *i* want to know is when/if/how we can get the rcd310 activated for DAB+ (ABC is broadcasting in digital now - http://www.abc.net.au/reception/radio/digitalradio.htm) especially since the AM radio is pretty crappy (yes, i'm a boring old fart)
    Jun 2009
    Western Australia
    Quote Originally Posted by Mclovin View Post
    Hi Mclovin, The MDI is a factory fitted option and cannot be installed at a later date. Hope that helps
    Jun 2009
    sydney,nsw
    Quote Originally Posted by vwnewbie View Post
    there are 2 types of MDI: one is factory fitted (with ports inside the centre armrest) and one is the "media in system" which gives you the port in the glovebox & is dealer-fittable.
    i've been led to believe the functionality (ie, control deives, etc) is more or less equivalent.
    Jan 2008
    Both the original MDI and the retrofit kit can be installed at a later date. Installation is straightforward for both.
    Jan 2008
    Quote Originally Posted by pwl View Post
    The retrofit kit will not operate with a revision A RNS 510 headunit however even if it's been flashed to the 1100 firmware and now shows up as revision B.
    The original kit can be retrofitted as well and can be removed from the cd housing to fit elsewhere in the car.
    http://www.my-gti.com/category/in-car-entertainment/mdi
