The ipod interface that you use when listening to it standalone is different to the ipod interface that VW have to interface to. Apple put a heap of restrictions on what can and can't be controlled via the interface and limit the data that is sent to the head unit. Apple also change these restrictions at times when can cause problems with headunits etc that used to work fine. Especially with the video out of the ipods this has been very problematical with Apple changing the specs a number of times.
Apple used to make a big thing about sticking it to the man (IBM) and ran quite a few ads along this time. Steve Jobs should look in the mirror because Apple has become everything they claimed they were not and then some. Their locked in hardware, poorly implemented features (to entice uses to the new model in 12 months), slow development and lacklustre development staff are only matched by the fanbois that rush out to buy the latest hardware just because it has the Apple logo. This isn't about bashing Apple but pointing out that Apple are a company that limit access to their hardware, make frequent changes without any notice, will do anything to capitalise on their captive audience and try to make out that they are an innovative company when they're not.
A 320gb 2.5" external hard will run from the MDI and costs around $50. It works without any of the problems of the ipod nor are you locked in to itunes and all the drm etc. The solution for the ipod problem is there but it requires you to make the move.
