Page 16 of 52 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 514
Thread: MDI niggles
  1. #151
    Jan 2008
    Quote Originally Posted by MkVIGTI View Post
    But I did notice that the sound quality seems to be better from playing CDs than from my iPhone.
    Who would have thought that a lossless format like CD would be better than an icrud playing back a lossy format.
  2. #152
    Feb 2009
    Re: MDI niggles
    Quote Originally Posted by Maverick
    How do you know he wasn't playing low bitrate mp3 on the phone?
    CD's will always sound the best but lossless is very close and the mdi sounds fairly good. Also on the stock speakers/amp you can't tell a huge difference.
    Lets hope VW bring out a new firmware for the MDI soon.
  3. #153
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by G-rig View Post
    Lol... only an Apple user could say a comment like that seriously!
    You do realise the big issue with that comment right?
  4. #154
    Feb 2009
    Re: MDI niggles
    Quote Originally Posted by coreying
    They should sound the same minus any loss through the mdi cable etc.
    I use flac at home on the pc with Foobar and that is just as good, so are wav files.
  5. #155
    Feb 2009
    Sydney, Australia
    That's what I'm trying to say. There should be NO difference between a lossless file and the original source.
    If there is, then the 'CD ripping' stage hasn't done it's job properly, or the playback chain is not up to scratch. Obviously Apple being Apple, and forcing users to only be able to hear their digital music via analogue output is the cause here
  6. #156
    Jan 2008
    It's irrelevant as it's a lossy format.
    But it's still not the same, being surprised that a lossless format sounds better than a lossy format is like being surprised that the sky is blue.
    Especially when the CD which is lossless is being played goes from a digital source to the headunit as a digital signal and is only converted to analog at the speakers whereas the icrud plays a lossy digital file converts it to analog is transmitted to the MDI and passed through to the headunit (I'm not sure if the signal is converted back to digital and finally back to analog at the speaker outputs at this stage).
    Clean out your ears!
  7. #157
    Feb 2009
    Quote Originally Posted by Maverick View Post
    We are all basically saying the same thing..
    My point is that most people may not hear the difference on the stock sound system between mp3 and lossless, however the better speakers/sound system the more you'll hear inaccuracies in low quality music rips/bitrates.
  8. #158
    Jan 2008
    Except you're doing the faithful Apple Fanboi argument and skirting around the fact that a lossy format (whether it be on an Apple Icrud or not) is inferior to a lossless format, personally I don't care as high quality MP3's are good enough given all the limitations with audio in the car.
    You would need ears full of wax to not hear the difference, even between high quality mp3's and a cd source you can hear the difference on the stock system.
  9. #159
    Feb 2009
    We are not talking about lossy formats, but apple lossless vs CD.
    I don't particularly like apple or itunes or apple lossless, but until there are head units out that support FLAC it will have to do, but interfaces with the car pretty well, except for the VW MDI bugs.
    I can hear the difference but it sounded like you couldn't if you think the stock MK5 setup sounds good. Although i may have got a dud car last time.
  10. #160
    Jan 2008
    Actually we're talking about icrud sound quality.
    Apple lossless may be close to CD quality but you forget that it's let down by the icrud that is playing it back. The sound quality will never be as good as a CD player in a head unit or a PC with a digital output to an amp or a CD player connected to an amp.
    If by will have to do you mean have multiple extra connectors, unshielded cables and so forth why not just use high quality MP3's?
    The stock setup is fine if you set it up correctly, if you start hacking away at the car slapping in different components than you'll end up with different results. The car environment is dreadful for music playback and spending $3000+ to get slightly better sounding music is a pretty poor return IMO. Spend $500 on a pair of headphones and use those in the car and pit the other $2500 towards a system at home where that money will yield better results.
