Page 3 of 52 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 514
Thread: MDI niggles
  1. #21
    Feb 2010
    Melbourne, Victoria
    Quote Originally Posted by Coaster View Post
    I fast-forwarded to the next track, the next track began playing but the last track name was still displayed. Pressing 'info' didn't update the name either.
    Got the same issue on our MkVI GTI with factory fitted MDI and the RNS510 head unit.
    Happens with a Gen 4 Nano, a Gen 5 Nano (video) and iPhone 3GS
    Been back to the dealer, searched the internet all to no avail......
  2. #22
    Dec 2008
    Perth
    Playback is less error prone on a USB thumbdrive.
    The only problem I've had so far is when I start the car again, the current tracks info isn't displayed, it just says 'no info'. It fixes itself with the next track.
    MY14.5 VW Polo 81tsi Comfortline - Candy White - Comfort Pack
  3. #23
    Feb 2010
    Caulfield, Melbourne
    Hey guys,
    How do you know if your MDI is a factory fitted or dealer fitted?
    Mine is situated in the arm rest of my 2010 GTI.
    My issue is that the playback quality is bad!, if I connect the same ipod via the AUX cable it sounds perfect but when playing via the MDI it sounds like its cracking and fuzzy.
    Anyone have the same problem?
    Any suggestions on how to mend this?
  4. #24
    Feb 2009
    Sydney, Australia
    If it's in the arm rest then it's factory fitted.
    As Maverick said in the other thread that you asked this question, the first thing would be to try another ipod/iphone. The output paths of the ipod are different via each method, so the fault could be in the device. Then if there is still an issue, put the car into the dealership to get them to check it out.
  5. #25
    Dec 2009
    Ripblade, there's a section in Setup that deals with Voltages. I can't remember exactly where but there are 3 options. Try going thru each one and you'll notice a huge improvement.
    The only problem as far as I can tell is the overall volume will be reduced.
  6. #26
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by xblode View Post
    Aah - this would make sense. The crackling could be occuring because you're exceeding the clipping level of the signal - which means you're exceeding maximum output volume (this doesn't have to occur with the speaker volume up loud).
    So the 'reduced volume' isn't a problem as such. All you're doing is setting the system to the CORRECT output volume of the ipod. Then you just turn the car stereo up louder to compensate
  7. #27
    Oct 2009
    Havent got those problems with my ipod connection, the problem I have had is NOW when the MDI has a ipod connected it doesn't detect is and says "no medium" same thing with the USB.
    Its been like that for a month or so, I've flagged it but decided I'll get it sorted when I get my drivers side mirror repaired.
  8. #28
    Feb 2010
    VIC
    Quote Originally Posted by ripblade View Post
    Hey guys,
    I have the same issue, played the same song on a burnt CD mp3 source, and via an iPhone and 4G iPod. Same distortion via the MDI and none via the CD player. How would we tweak the voltages? via VAG-COM?
  9. #29
    Feb 2009
    Sydney, Australia
    Did you read the manual ?
  10. #30
    Feb 2010
    Hi xblode,
    I will look in the manual for these settings and give it a try.
    Just for clarification on the problem, when I plug the ipod in via the Aux port and have the ipod set on full volume the distortion i hear is the similar as the distortion I get when the I plug the ipod via Mdi. If I turn down the volume on the ipod when plug via AUX and then pump up the volume on the car it sounds perfect but I cannot access the ipod volume controls when its plugged in via MDI.
    So based on what you said there should be an option somewhere in the headunits setup to make these changes for the MDI option, I will power thru the manual and let you know if it works!
    Thank you!!
