Page 46 of 52 FirstFirst ... 364445464748 ... LastLast
Results 451 to 460 of 514
Thread: MDI niggles
  1. #451
    Mar 2011
    Brisbane, Qld
    dandy! thanks for that really quick reply. i see why using a USB stick makes so much more sense now!
  2. #452
    Apr 2010
    Adelaide, South Australia
    can someone tell me 2 things:
    1) how can you view iphone video on rns510 (video in motion? what part how (professional?) to install it where is it placed...) I do have rev cam factory installed. I have seen some posts on you-tube but not really much detail..
    2) is there any 3rd party plug that can bridge MDI cable and Iphone so that "accessory connected" splash screen is not on...?
    GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
  3. #453
    Apr 2010
    1. I've seen video-in adapters for the RNS-510 - I'm not sure where you'd route the cables or how messy it would look though.
    2. You're other option would be to connect your phone via the 3.5mm AUX jack (usually inside the center console), but then you wouldn't be able to use the steering wheel controls to select or skip songs.
  4. #454
    Camberwell, Vic
    As a follow up to this, and one quick question. By chance, I found (and it may well be in the manual but I missed it), those with RNS510 but no phone - if you push the phone button while the ipod is playing, it both mutes and pauses. Push it again and it starts again.
    I'm confused as to why the ''phone' button on the steering wheel does not do the same since it would be so easy. And it would seem this is a button that is not functioning at all.
    Can those with MDI and RNS510 just check this for me on their vehicles please? Cheers
    2010 R36 (MY10.5), Biscay Blue, RNS510, MDI, Electric tailgate, sunroof, Superchips remap - SOLD
    2016 Octavia VRS wagon, moon white, Tech Pack, 18" black pack, electric boot, panoramic sunroof, Bluefin
  5. #455
    Apr 2010
    The Microphone button on the wheel does the pausing - I installed the RNS 510 and Bluetooth and decided to keep the button used for that instead of voice control due to personal preference.
  6. #456
    Nov 2009
    Quote Originally Posted by slipshot View Post
    Mine behaves exactly as yours does.
    My mic button activates voice control (and yes, pauses the music). I never use voice control, so if I want to pause whatever's playing, I use the phone button on the headunit.
    If there is an easy way to code the Phone button on the wheel to perform the same function as on the headunit, I'm all ears!
  7. #457
    Mar 2010
    Quote Originally Posted by AdamD View Post
    Thanks Corey.
    There's nothing specific in the PDF that I can make out (it's dated 2010), but the update itself is linked as KW22 2011 - so build week 22. It's definitely a later firmware than the KW22 2010 firmware listed on my-gti.com. I've just applied it to my MDI and it seems to work a treat.
    Update KW22/2011 MDI Firmware
    Installation instructions (from my-gti.com KW22/2010 page):
    • Download the firmware (see link above)
    • Copy the file mdi.bin.enc in the root (top) level of a USB flash drive and insert this into the USB cable.
    • Turn the headunit on or start the car and the update will proceed. If the MDI is selected the status will be displayed.
    • After around 1 minute the update will complete and the USB flash drive may be removed.
    I tried to apply this update but the screen displayed that the software update is not possible?
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
  8. #458
    After having the firmware update for over 6 weeks now, I still get the occassional skip using the iPod. Nowhere near as much as before, but still annoying.
    Golf R : Rising Blue : DSG : 5 door : Leather : 18" Wheels : Reversing Camera : Bluetooth : MDI : APR Stage 1 : Focal Speakers : Hertz Sub : Alpine Amps : Opti-Coat : Weathershields
  9. #459
    Nov 2009
    Quote Originally Posted by MkVIGTI View Post
    Sounds like you already have it?
    Remember that you'll only see the update status if your head unit is in MDI mode when you plug in the USB stick. If it's not, you might find that the MDI will be updated, but you won't know. If you then switch to MDI mode, eject and reinsert the USB stick, you'd get that message - solely because the unit is now up to date.
    Failing that... check the USB stick is formatted FAT (not NTFS, HFS+, EXT2 etc etc), and that the update bin file is correctly named and in the root directory of the USB device. If that all checks out, re-download the file, reformat the USB stick, rince and repeat.
  10. #460
    Mar 2010
    I probably have updated it already because I re-downloaded the file onto a different USB but it's still the same.
