I recently installed the MDI in my car (I'll endeavor to get pics later) and had a quick question (searching Google and here didn't help) - are we supposed to be able to copy MP3 files from a USB stick to the RNS510 HDD like you can with an SD card?
I had this expectation in mind when I got the device and was a bit miffed to find the option missing. I've also upgraded the firmware from the My-GTI site. I can of course understand not allowing the copying of files from an iPod, but I thought an exception would be made for USB drives. I'm always telling myself to 'remember to grab the SD card out of the car next time I go to work so I can put more music on it', followed by me getting off the train and going d'oh. Using a USB stick would be much better for me.
For those who have MDI, do you also have a separate AUX input, and does it function? If I connect the MDI box to the system the 'AUX' label on the RNS changes to MDI and AUX doesn't function (which is reasonable I guess, unless there's a VCDS settings somewhere I can change). Since upgrading the MDI firmware, when the MDI is connected but no device is attached, it allows me to select 'MDI' (not greyed out) and then where the song title would go it says AUX, but the AUX line isn't active still. I could always get the MDI 3.5mm audio jack adapter if I really wanted, but just checking first.
