well, in all fairness, G-Rig's ipod has a hard drive in it as well (albeit 1.8" rather than 2.5")
Or maybe he has the input sensitivity set incorrectly![]()
Easy fix. Record one big MP3 file and you'll have your gapless playback!
And if you upgrade you stereo you won't be using the MDI anymore so problem solved!
I'd put money on it being the head unit.Anyway it worked properly with the previous MDI that we installed so my bet is that the new VW firmware has stuffed it up and would be worth reverting back to the previous version if possible as it works flawlessly before (same ipod too 5.5G & same 3G iphone).
Android FTWApple is fking annoying and itunes even moreso , will eventually do away with both. Just like when they changed to 5V and a lot of head units or chargers wouldn't charge the iphone.
If people are entitled to complain about small rattles then i can for this LOL. VW owners are fussy people.![]()
website: www.my-gti.com
If it's mounted correctly, and remembering that 2.5" hard drives have tolerance for movement and a reasonable sized cache it should last for a long long time. $50 get's you 2-3 years warranty as well so it's a lot cheaper than buying an iturd. Alternatively 64GB USB flash storage is cheap and 128GB is coming down in price.
Could well be this new version of RCD510 (with the AM/FM buttons, last one was fine), bit of a gamble to buy an RNS510 though if it doesn't fix the problem. Anyway can always listen to cds i guess once the speakers and amps are in.
Does anyone know if there is a way to set the iPod playback to playlist not songs as a default? It's starting to irk me having to go backwards and search my playlists!
