It doesn't look like anything as you can't see it. The cable is the exact length you require (you push the rest into a cavity behind the glovebox) and whatever you're using in there (memory stick, hard drive or icrud/iturd) can be mounted in a pro clip style holder on the roof of the glovebox or below the manual under there. Doesn't take up any space, it's secure from moving around (important if a usb hard drive), has protection from the elements when parked and is cooled when the car is turned on.
You can also lock the glovebox and if the unit is mounted up high it wouldn't be noticed unless you had a good look.
