I usually have the arm rest up two notches so should be ok.Quote:
Originally Posted by Dermot
Printable View
It doesn't look like anything as you can't see it. The cable is the exact length you require (you push the rest into a cavity behind the glovebox) and whatever you're using in there (memory stick, hard drive or icrud/iturd) can be mounted in a pro clip style holder on the roof of the glovebox or below the manual under there. Doesn't take up any space, it's secure from moving around (important if a usb hard drive), has protection from the elements when parked and is cooled when the car is turned on.
You can also lock the glovebox and if the unit is mounted up high it wouldn't be noticed unless you had a good look.
So what? :)Quote:
Originally Posted by Maverick
Just saying that is a good height for my arm.
The problem is the cable gets bent each time you close the lid.
You may have it up two notches "so it's not a problem" but everytime you open the lid you have you to close it all the way down before you can lift it up.
So the cable still suffers from the same problems.
What if you put the iPod in the other way around with the cable at the bottom? Sounds like I should mod the cable.
I'm going to leave mine in there all the time so prob doesn't matter (too much trouble using the iPhone as you have to connect it everytime you get out of the car).
You can adjust the levels but still sounds crap.
