Results 1 to 3 of 3
Thread: Machine wheels good or bad?
    Sep 2018
    Gold Coast
    Hey guys
    So I’m running 19 8.0 et 40 with Yokohama advan 35 225 and I scrub , I’m
    Thinking about machinery 5 mill to turn into 45 offset as factory offset . Has anyone done this before ? Thanks in advance
    Usually most wheels have 2-3mm max that can be taken off.
    Usually the length of your wheel bolts will tell you how much “meat” there is.
    If you’re running longer bolts than stock then you have half a chance.
    Tigger on the money.
    I've had it done on a couple of wheels for repairs more so than changing the offset. Ensure your brakes will still clear too
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
