Results 1 to 3 of 3
Thread: Loose Windows
    Loose Windows
    I just noticed when I press my hand on all windows they make a creaking sound because they're a bit loose. Anyone have/had this? Is this covered by warranty?
    Here's a video clip: https://youtu.be/zY2xqDBdlIY
    Jan 2013
    Brisbane, QLD.
    Hey mate, if your car is covered by warranty take it to the dealer, this will be covered, looks like the window regulator clamps have come loose (or the split pins) depending on which design is in yours....
    Apr 2015
    Strathfield
    Does the car make the same type of noise on bumpy roads? Is so it is the door seals squeaking up against the vehicle body. The Volkswagen dealer can apply a solution called Krytox to address the problem (it's a common problem). They should cover it under warranty.
