Originally Posted by
brad
Well, i guess you should aim for a narrow 17" rim (6.5"-7") that weighs a max of 8kg & 205/50x17 tyres (light ones).
Very hard to do that and maintain the required load rating on the tyre due to the reduced air volume - you might be forced to fit a light truck tyre.
Resident grumpy old fart
