Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Looking to upgrade to 17" wheels
    Oct 2010
    Melbourne, VIC
    Well, i guess you should aim for a narrow 17" rim (6.5"-7") that weighs a max of 8kg & 205/50x17 tyres (light ones).
    Very hard to do that and maintain the required load rating on the tyre due to the reduced air volume - you might be forced to fit a light truck tyre.
    Resident grumpy old fart
    Jan 2009
    As valid as the points on increased fuel consumption are, I wouldn't go chasing lightweight wheels for what is an urban runabout for the wife.
    Those particular Bridgestones will indeed help to offset some of the energy loss, and if you buy a set by the end of June, you'll receive a $50 fuel card from BP (see Bridgestone's website).
    If you want to stick with OEM wheels, VW have about 11 designs in 7.0 J x 17 ET54 for the Mk6 Golf, so you have plenty of choice.
    They also have about 5 wheels in 7.5 J x 17 ET51 (for models with sports suspension) but I'd stick with 7.0 J x 17. The narrower wheel will be ever so slightly more compliant as well, in terms of ride comfort.
    There's one 6.0 J x 17 ET48.5 wheel that's designed to be fitted with 205/50 R17 93H XL tyres (for winter usage) but I doubt you'll find a set in the country unless it has been ordered from Germany.
    Jun 2012
    Quote Originally Posted by Diesel_vert View Post
    They also have about 5 wheels in 7.5 J x 17 ET51 (for models with sports suspension).
    Thanks for the replies all.
    The bluemotion does have sports suspension BTW. Are the Seattle wheels 7.5's?
    *Edit: Yep, the Seattle's are 7.5
    Jan 2009
    Quote Originally Posted by Jamar View Post
    The Seattle wheels are 7.0 J x 17 ET54.
    There is a mistake in the Australian brochure for the Golf. On page 38, it incorrectly lists them as 7.5 x 17. Yet on page 43, it correctly lists them as 7.0 x 17.
    In any case, I'd stick with them. And the Golf GTD has the exact same wheels.
    Jun 2012
    There you go. I just did some more searching and found a picture of the inside of the wheel that shows the size as 7.0Jx17H2 ET54.
    Good to know, thanks Diesel_vert
    Jan 2011
    Brisbane - QLD
    i recommend to go with 17x8 Rays forged lightweight 6.5kg a wheel to save petrol
    Erskineville, NSW
    Enkei have a very nice RPF1 in 17x7.5 that weighs <7kg & would come in at about $1300. If you squint, it looks similar to the seattle
