Really struggling to find a thin 16mm spanner, can the job be done without it?
http://images.cycle-street.co.uk/ima...maxheight=1200
Found something! I can get one of these today. Would it do the job? It's a pushbike spanner ...
I can cut the plastic handle off. The one I'm getting is similar. The plastic is just a coating over the metal underneath so i'll remove it if it's an issue.
Job done, 4hrs or so it took me as I was going slow to make sure I did it right. Reset Ecu fault codes with my uncles obd scanner and boom everything is working perfect now. Thank you so much for your input as it made it a breeze to do having the right equipment handy. Cheers
Good job mate, any really ****ty bits to report?
Nope, was quite easy. Pulled off front drivers side wheel and inner guard to gain side access, made it heaps easier. It's a pita job though to be honest, lots of fiddly crap.
The boost pipe is what I hate, hard to get it out due to the tight space![]()
Hi, I have replaced my water pump but my supercharger/belt isnt moving! How do I check if the fuse is blown? How do I replace the fuse for the Supercharger and where is it located?
Sent from my SM-G975F using Tapatalk
