Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Limp mode + Blown fuse
  1. #21
    Really struggling to find a thin 16mm spanner, can the job be done without it?
  2. #22
    Quote Originally Posted by smokiebbear View Post
    Make one with an angle grinder. Buy a cheap one and make it fit.
  3. #23
    http://images.cycle-street.co.uk/ima...maxheight=1200
    Found something! I can get one of these today. Would it do the job? It's a pushbike spanner ...
  4. #24
    I imagine thats what you want. Have you looked on teh car to see what access you need. ie Will the plastic handle on the spanner be a hinderance?
    I think grinding down a cheap spanner is a good solution still, unless you haven't a grinder.
  5. #25
    I can cut the plastic handle off. The one I'm getting is similar. The plastic is just a coating over the metal underneath so i'll remove it if it's an issue.
  6. #26
    Job done, 4hrs or so it took me as I was going slow to make sure I did it right. Reset Ecu fault codes with my uncles obd scanner and boom everything is working perfect now. Thank you so much for your input as it made it a breeze to do having the right equipment handy. Cheers
  7. #27
    Nope, was quite easy. Pulled off front drivers side wheel and inner guard to gain side access, made it heaps easier. It's a pita job though to be honest, lots of fiddly crap.
  9. #29
    Jul 2012
    Sinagra, Western Australia
    The boost pipe is what I hate, hard to get it out due to the tight space
  10. #30
    Hi, I have replaced my water pump but my supercharger/belt isnt moving! How do I check if the fuse is blown? How do I replace the fuse for the Supercharger and where is it located?
    Sent from my SM-G975F using Tapatalk
