My left foot must be mildly retarded. I can't even brake smoothly at a red light with my left foot, let alone do it on a race track!
Another point we haven't covered, specific to motorsport
Prior to arrival at a corner it's entirely normal to use the left foot to jab the brake peddle
This is to check if there are any brakes and to deal with "pad knock off" (push the pads right up to the disc)
If you've clobbered the apex the impact can knock the pads back from the rotor disc
Next time you go to hammer the brake at the very last second you will get a long peddle and may not make the corner (certainly not the apex)
You could not do this in a race if the ECU shut the throttle down when you jab the brakes
It's something you have to tune into and get used to...
I learnt to left foot brake in recreational 4wding as my vehicle at the time had an extreme distance between the pedals and when wearing hiking boots it could be a bit clunky to use.
I now find myself doing it every day in traffic. There's not alot of benefit, except perhaps faster reaction times when stopping but that is hardly a major issue, I'm not a tailgater.
