Page 15 of 31 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 302
Thread: LED Number Plate Lights
  1. #141
    Feb 2010
    South Perth, WA
    Quote Originally Posted by chopper View Post
    OK... I have discovered the first problem with my R-Dash lights!!!
    When they are on... You lose ALL AM reception! I assume it has something to do with the Resistor Box?!
    Is anyone else having this problem... could those of you with them installed please check and let me know if you also lose AM reception. I'd like to fault find and see if it is due to the way I have installed them, if I have a faulty unit or they just all do it!
    I assume the OEM units don't have this problem... I might have to try these at some point! I really like my talkback radio... can't do without AM reception at night!
    Checked with the lights and radio on but engine off (as it's late and I didn't want to wake everyone :p) AM reception is fine for me! Will try again in the morning with the motor running but don't think this will make a difference. btw I have the R-Dash leds.
    WLF127
  2. #142
    Quote Originally Posted by shakespeare View Post
    Hmmm... maybe it isn't the R-Dash LED's?! I just assumed it was, because when I turn the vehicle lights off, the signal returns (or the static disappears, which ever one is right?). The only difference is the number plate lights.
    I wonder if it is how I've installed them... I cable tied the Resistor Box back on the cables... perhaps the "coil" is inducing an EMF which is creating the interference?! How did you install them?
    Now - MY17 Passat 206TSI Wagon - Tungsten Silver | Sunroof
    Previous - MY11.5 GTI 5Dr - Reflex Silver | DSG | ACC | Sat Nav | RVC | Bluetooth | MDI | 18" Detroits | Park Assist | Bi-Xenon's | Leather | Sunroof | R-Tails
  3. #143
    Also... do you have the RNS510 (and consequently, the "Shark Fin" antenna)? I am wondering if it also might have something to do with my antenna placement in relationship to the LED lights?!
  4. #144
    Jul 2011
    Slacks Creek QLD
    is there a better & longer aerial for the golf?
  5. #145
    Dec 2010
    HAHAHAHAHAHAHAHHAHA.... wtf? I just tried in my car and I have the SAME problem. AM Radio = ok. Turn on the lights, AM radio goes into a black hole. Turn off lights = AM radio comes back.
    I guess for me it's not a huge problem because I rarely listen to the radio (AM or FM). But wow... that spun me out. And I know my AM radio was working fine before with the OEM lights in.
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
  6. #146
    Feb 2009
    Sydney, Australia
    A few clarifications here.
    Even if you have the RNS-510 Sat Nav, the antenna on the roof is just for GPS. It's not for radio reception.
    I can confirm that, even with the sharkfin, the R-Dash LED Lights DO STOP AM reception.
    After reading the above comments, whilst I was washing my car this morning I unplugged the connectors and turned on the parker lights and AM reception is fine.
    So if you care about AM reception, I suggest you just pay up for the $180 OEM VW LED lights and find a solution for the error code if you get it.
  7. #147
    Mar 2008
    Sunshine Coast
    Dammit, just ordered them
    Oh well, I have TuneIn on my iPhone so I can play AM on that.
    So, these don't cause any error code but the OEM units do ?
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  8. #148
    Feb 2009
    Sydney, Australia
    The OEM ones come standard on MY12 cars which are optioned with the Xenon lights. It's likely that there is something in the MY12 cars which means they work fine, but in older cars they cause error codes. The information on which cars will have error codes and which ones won't is still sketchy
  9. #149
    Quote Originally Posted by Candyman View Post
    TuneIn is awesome! That's what i've actually been doing on long drives... and it works quite well... except for the odd "Crackle" going through the system... which I suspect is an interface thing (does it during iPhone music as well)!
    One of the Guys has an OEM set on order... i'm waiting with bated breath to see if his car throws up an error code. As I have an MY11.5 car with Xenon (Mar/April build)... I am kind of assuming I won't get the codes, but given the kind of luck I have been having, I probably would!
  10. #150
    Feb 2010
    Not sure what's up with your lot but mine works fine. AM radio is clear as.
    2011 Mk6 GTI | CW | DSG | Bi-Xenon | GIAC | APR TBE | THS FMIC | Modshack
