Page 29 of 31 FirstFirst ... 192728293031 LastLast
Results 281 to 290 of 302
Thread: LED Number Plate Lights
  1. #281
    Oct 2013
    Central Coast, NSW
    Quote Originally Posted by AutoSlick View Post
    why are the JOM ones more expensive than the latter ones?
    Thanks.
  2. #282
    Jan 2012
    Epping, NSW
    The other has some seriously large butt ugly resistor banks (but I suspect with coding, you could avoid needing to fit them).
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
  3. #283
    Quote Originally Posted by tonymy01 View Post
    ^ as mentioned by tonymy01 - the cheaper (Racing Dash) LED's have a little resistor/heat sink box (about the size of a match box) that is needed in order for the LED's to work properly. They fit up inside the bumper cavity and use double sided tape to secure on a ledge. Mind you, there are stacks of Mk6 users with these Racing Dash lights (including myself) and they work perfectly. No errors, no issues and super bright.
    These JOM units are new to the market, and i have not seen any photos of the light output that these give. Until these JOM units became available, the only option was the Racing Dash brand and another brand which i cant recall the name of right now. But Racing Dash were the more popular ones.
    I like the fact that the JOM units don't need the resistor box, but they only have 3 LED's so the light output will be less than the Racing Dash units which have about 18 LED's or so.
  4. #284
    Nov 2009
    I used to use the Racing Dash lights, with custom adapters I soldered up (the RDash heatsinks were rubbish quality and occasionally caused a fault code for me). That solution worked well - as mentioned, they are bright and throw a fairly uniform light - until the wiring into one of the LED housings started to fray at a point that was difficult to access or repair, causing the light to cut out intermittently.
    So I bought OEM LEDs and adapters from carsystems.pl; cost about $100 all up. The light is far dimmer than the RDash LEDs overall (they utilise two large LEDs rather than 10+ smaller LEDs), but also draw a lot less attention to the numberplate area. Overall the look is much more OEM. The only downside of this for me is that it's now harder to see the ground via the reversing camera when backing up at night. The build quality of the LEDs and adapters is vastly better than the RDash units - as you'd expect given the higher cost.
  5. #285
    Nov 2012
    Brisbane, Queensland
    Ended up getting these from auto slick and can also recommend them. Good product.
  6. #286
    Nov 2012
    Nov 2009
    Quote Originally Posted by vw_alex View Post
    They're the RDash ones.
  8. #288
    Im very tempted to buy the more expensive JOM ones that Slickonline have - hoping to get more light than the OEM led's (which ive had previously - not enough light for me) and my Racing Dash ones (which work well but too bright).
    The 3x larger LED's on the JOM ones will hopefully be a good compromise between OEM and Racing Dash. Just trying to justify the $109 cost. VW (Volkswagen) LED License Plate Upgrade | SlickOnline - AutoSlick & HomeSlick
    Is anyone on here running the more expensive JOM ones? Feedback?
  9. #289
    Jan 2012
    Hi, could start a new thread but thought I'd post here because it's active.
    I have the Racing dash led number plate lights and love them. Had them from day one 3 years ago with no problems until now. One of them has come unplugged and fallen down somewhere behind the bumper. The weight of the resister must be holding down out of the way as I can't see it through the hole where the light fits. Any ideas of a quick and easy way of getting to this wire harness without too much fuss as I am useless?
    2015 Golf R. Lapiz Blue.
  10. #290
    Use a bit of wire (old coathanger will do) to make a hook and pull the wire back through. Did you have the resistor boxes stuck inside the bumper with double sided tape?
    If you cant get to it with a metal hook, try taking off your diffuser (4x screws, takes all of 5 mins to get off) and accessing from underneath.
