Page 19 of 31 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 302
Thread: LED Number Plate Lights
  1. #181
    Feb 2009
    Sydney, Australia
    Yep, I did.
  2. #182
    Dec 2010
    Ok cool. I'll send them an email too. Will try some experiments tonight with the lights aswell and will post the results.
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
  3. #183
    Jul 2010
    just got mine in the mail...
    Did you guys register on their site for warranty?
  4. #184
    Nov 2009
    SEQLD
    Just checked my batch number 11-03 and I have no problems.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
  5. #185
    Dec 2010
    Ok - some very interesting results.
    The resistor boxes aren't the problem - it's the lights themselves.
    These are the tests I just performed.
    R-Dash lights in the Golf R, lights turned on. AM reception in the Golf R = bad. AM reception in the Tiguan parked right next to the R = good.
    R-Dash lights in the Golf R, lights turned off = AM reception good in Golf R
    R-Dash lights in the Golf R, resistor boxes plugged in, LED lights unplugged, lights turned on. AM reception = good.
    R-Dash lights in the Golf R, LED lights plugged in, resistor boxes unplugged. AM reception = bad.
    Now here's the interesting thing.
    If only ONE of the LED lights is plugged in - AM reception = good.
    It only seems to be an issue when both LED lights are plugged in.
    I also wrapped up each LED light in a ball of aluminium foil, and it made no difference. I suspect that it's some kind of resonance between the two LED lights that's being put into the wire.
    My car: MY18 Arteon
  6. #186
    Dec 2010
    Quote Originally Posted by Corey_R View Post
    So I had a little play around with the R Dash LED lights.
    The actual LEDs can be plugged in either way - by that I mean the plug which goes into the LEDs isn't "keyed", and so it can go in both ways. It's only a 2 pin so it's not overly important. But I did the following:
    - Disconnect both, AM fine
    - Connect left light plug pins "up", AM fine
    - Switch left light plug pins "down", AM fine
    - Connect right light plug pins "down", AM interfered.
    - Switch right light plug pins "up", AM interfered.
    - Switch left light plug pins "up", AM interfered.
    - Switch right light plug pins "down", AM interfered.
    - Unconnect left light, AM fine.
    So effectively, it doesn't matter what way the cables are plugged in, nor which side light is plugged in... as soon as you have both lights plugged in, the AM is interferred with.
    Ahh - my bad... I didn't see Corey had already done this.
    Also my batch is 11-06.
    My car: MY18 Arteon
  7. #187
    Jan 2011
    Interesting. The LED bulbs I ordered from eBay (w5w 194 5050 SMD canbus no error LED) had a problem that when I had one LED and one normal bulb in it was fine, but as soon as I put a second one in (no matter which bulb or which side) the MFD would display the "check number plate light". Didn't try the AM radio at the time...maybe I should?
    Anyway, gave up on those and ordered some R-Dash ones that seemed to be error free...
    MY11.5 Golf R - Candy White 5 door - still giggling like a child when I drive it!
  8. #188
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by DreamensioN View Post
    Yeah I did. But my conclusion isn't that it's not the resistors. I mean, I have no method of determining which one it is. It's possible that the resistors are "in active" until the LEDs are plugged in and the circuit is complete etc.
  9. #189
    Email reply... in their best broken Taiwanese English...
    Sorry to make you feel inconvenient very much.
    Because it has not ever happened before, please give us some time to find out what the problem is.
    We'll response you as soon as we've the solution.
    The customer service alone is worth the $43!
    Now - MY17 Passat 206TSI Wagon - Tungsten Silver | Sunroof
    Previous - MY11.5 GTI 5Dr - Reflex Silver | DSG | ACC | Sat Nav | RVC | Bluetooth | MDI | 18" Detroits | Park Assist | Bi-Xenon's | Leather | Sunroof | R-Tails
  10. #190
    Nov 2010
    Melbourne, VIC
    Quote Originally Posted by chopper View Post
    Not very exposed to international trade are you? I think they're the ones laughing all the way to the bank mate
    | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
