Results 1 to 10 of 18
Thread: Just Fitted GTI Steering Wheel to base Golf - Problems
    Oct 2011
    Chingwyn, Vic
    H1,
    Fitted a brand new GTI wheel to my MY12 Mk6 Golf that had a basic plastic wheel.
    The Airbags were identical - but I used the new one, but could have used either.
    The problem I now have is that Horn does not work and 5 of the dash lights stay on.
    Anyone else had this problem ?
    thanks
    Digger
    Nov 2009
    SEQLD
    No problems with my install but my golf is a comfortline. You sure the airbags are identical? Do the multifunction buttons work?
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
    Oct 2011
    Chingwyn, Vic
    Update,
    Went for a drive and turned the wheel all the way to the left and then all the way to the right. All warning lights now gone off.
    Only left with the Horn not working now.
    Is the horn part of the Airbag module ? If so, I could swap back to the old Airbag as it did fit.
    As it is a 77TSI - I would have to change control module to get the buttons to work - so I didin't bother with that.
    thanks
    Digger
    Nov 2009
    SEQLD
    It could be the module. My original airbag was completely different to the GTI airbag.
    MY20 Golf GTI TCR
    Oct 2011
    Chingwyn, Vic
    Does your Horn work ?
    Nov 2009
    SEQLD
    Yep! Everything works like it should
    MY20 Golf GTI TCR
    Apr 2010
    lol I don't think I've even tried to use my horn since (I did think I should test it after retrofitting but never had an appropriate opportunity). That said, last week I had over 5 people come close to side-swiping me due to not looking when changing lanes, but between avoiding a collision and downshifting I never got around to using the horn (plus I don't like the sound of the Golf's horn).
    I'll try and test it later on.
    Also keep in mind that the horn doesn't work w/o ignition, in case that's how you were testing. As far as the control module goes, didn't that come with your new wheel?
    Oct 2011
    Chingwyn, Vic
    No, the control module is the SWCM which is a separate part.
    Will try turning the ignition on for the Horn, assumed it would work without, every other car I had it did.
    Mar 2010
    Witness Protection
    Quote Originally Posted by Digger11 View Post
    This oversight was discussed (argued) extensively here about a year ago when one member was sitting in his car and watching someone about to reverse into it, but the horn wouldn't work.
    Nice pick up Ryan_R.
    Jul 2011
    Brisbane, Queensland
    The SWCM on the new models is actually part of the slip ring which forms the base of the control stalks. I retrofit a MFSW onto my 77TSI and had to upgrade the SWCM as part of the process (which also enabled me to install a cruise control stalk). Then Vag Com the wheel to get the buttons, lights, horn to work. All in all probably the best upgrade to my 77.
    Dave
    New Ride: MY19 PW R Special Edition
    Past: MY12 5dr CW Golf GTI Manual
