When you say 'sports mode', do you mean that you have it in S and THE CAR shifts to 1st itself?
Or do you mean you have it in 'manual mode' and YOU shift it from 2nd to 1st?
If it's the former then take it out of S and put it into D before going so slow as to pull into a driveway.
If it's the latter and you're changing into 1st, then don't! Even a manual would do what you are describing. The GTI has plenty of power and torque even at low revs, so 2nd is fine. If you go so slow that it has to shift into 1st to prevent stalling, then it will do it itself without having the issue you describe.
Hope that helps![]()
