Page 2 of 2 FirstFirst 12
Results 11 to 20 of 31
Thread: It's official, GTI & GTD
    Nov 2006
    Canberra, Australia
    GTD & GTI announcements have to be coming soon, surely.
    Volkswagen Launches Most Fuel Efficient Model – Golf 77TDI
    The new Golf range now features the most fuel efficient model in the Volkswagen range with the addition of the new 1.6-litre diesel Golf.
    Powered by a sophisticated and efficient new diesel engine, the five-speed manual Golf 77TDI can cover 100km with 4.9-litres on the ADR 81/02 combined cycle. In highway running consumption drops to just 4.3-litres per 100km.
    With a potential range of well over 1100km, the new diesel Golf not only delivers its occupants in comfort and safety to their destination but at minimal expense.
    The sixth generation of the Golf establishes an elegant new design direction in the evolution of the iconic model.
    In conceiving the interior for the new Golf, Volkswagen’s designers unashamedly set themselves the target of defining new benchmarks in quality in this class. This goal extends to all aspects, from ergonomics, through the feel and look of the materials used to the overall refinement within the cabin.
    The new interior look is combined with advances made by Volkswagen engineers in reducing wind noise, including a completely new design of door and window seals, a new sound-damping inter-layer within the laminated windscreen and a new engine mounting system. The result is the quietest Golf yet produced.
    The new 1.6-litre diesel, shares the same technology as the 2.0-litre diesel (103TDI) with 16-valves and common rail fuel injection. It produces peak power of 77kW at 4400rpm, while maximum torque of 250Nm is delivered between 1500-2500rpm. Fitted with a standard DPF (diesel particulate filter) to reduce particulate emissions, this new engine is not only one of the most efficient but also one of the cleanest diesels available.
    Two transmissions are on offer, a five-speed manual and a seven-speed DSG.
    The seven-speed DSG transmission uses a pair of dry clutches (as opposed to the wet ones in the six-speed version) to improve fuel efficiency and performance.
    The pair of dry, organic bonded friction linings do not require cooling, making the drivetrain more efficient through the extra gear ratio and the fact that less power is required for the gear selection and clutch servo system. Measuring only 369 mm in length and weighing only 79 kg, including the dual-mass flywheel, the gearbox is remarkably compact.
    In adopting seven-speeds, Volkswagen engineers were able to lower first gear to improve acceleration from a standstill. By contrast seventh gear has been raised to act as an overdrive function making it ideal for motorway driving with the additional effect of further improving economy and comfort levels.
    The lubrication circuits are divided into two to maintain the purity of the oil. As with a conventional manual gearbox, one of the circuits is used for cooling and lubrication of the gear teeth, the second feeds oil to the gear actuators. Since the clutch does not require cooling the quantity of oil has been reduced from 7 litres in the six-speed DSG gearbox to only 1.7 litres in the new seven-speed system.
    The Golf uses proven MacPherson strut-type front suspension to offer direct steering feedback, strong axle rigidity under cornering loads and minimal body roll.
    Ride and handling benefit from the car’s clever mounting concept for the lower wishbone with separate mountings for spring and damper on the suspension strut tower, including a lightweight twin-sleeve damper unit and optimised spring rates.
    The previous Golf’s completely new four-link rear suspension system was a major stride forwards for this market segment in terms of providing the optimum combination of handling dynamics and ride comfort.
    The compact four-link layout features three lateral control arms – the spring mounting, the track rod and the upper control arm – and a trailing link at each wheel. Suspension assemblies are attached by way of a rear-axle subframe and, as at the front, rubber-and-metal mountings that are soft in torsion but stiff radially are used to ensure that the anti-roll bar responds immediately and suppresses body roll effectively. This combines accurate handling with good ride and low road noise levels.
    The spring and damper on each side are located separately; the spring bears directly on the trailing link and the damper unit is attached to the wheel hub assembly.
    The suspension geometry on the compression stroke generates a toe steering effect that maintains neutral behaviour or slight understeer in all driving and load-carrying situations.
    Among the benefits of the almost neutral layout are excellent straight-running stability characteristics on highly uneven road surfaces and minimised tyre wear.
    The Golf uses a third generation electro-mechanical power steering system (EPS) which is able to vary the feel of the steering wheel to suit the speed and driving situation: firm and direct when driving hard, effortless at parking speeds.
    Other advantages of the system include its mild self-centering action, its ability to compensate for different driving hazards, like crosswinds and steep road cambers, and a beneficial effect on fuel economy.
    The Golf features a sophisticated braking system, with ABS and ESP (Electronic Stabilisation Programme) as standard across the range.
    On the passive side, there is a further perfected safety body (including additional reinforcement in the door area and optimized pedestrian protection), seven airbags including a knee airbag on the driver’s side and a patented safety optimised head restraint system for driver and front passenger.
    As the entry-level diesel the Golf 77TDI starts at $28,690* for the five-speed manual, while the 7-speed DSG variant is priced from $31,190*.
    * Prices are manufacturer list prices only, for the drive away price please contact your local authorised Volkswagen dealer.
    MY10 S3 3dr
    Aug 2009
    ferntree Gully
    Quote Originally Posted by Coaster View Post
    But only in Trendline... I'd prefer small engine, big features.
    You can get a comfort pack on a trendline to take it up to the same equipment level as a comfortline
    Aug 2009
    ^^ Minus the 16" alloys, rear seat arm rest, comfort seats.
    Mar 2009
    Apparently the 5 Door Golf 1.6 TDI Trendline w/DSG will be $35571 Drive away (full retail).
    Can be optioned to Comfortline for $2200 (possibly same details as taking a 90TSI from Trendline to Comfortline)
    Cars should be in dealerships within 6 weeks.
    That's with the 77Kw version, not the 90Kw TDI engine.
    DSG appears to be 7 speed.
    MY09 Silver Leaf 118TSI DSG, & MY09 Candy White 103TDI DSG
    Nov 2007
    Golf GTD availability
    Also see my post on the Golf R ....
    Also saw a note (official VW) stating that the GTD will be released in Australia in May 2010 ..... deliveries to start end May beginning of June .....
