![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
jamesatfish
Again, I recommend doing your own research in this regard. Check your insurance policy PDS for such clauses - I know that my insurer does not list any such exclusions.
Also consider whether your belief in the improved safety of an overseas spec seat is worth more than the monetary value of your insurance policy. Personally I'd chose the safest option for my kids as the only concern, rather than picking a less safe option because I might be less out of pocket in case of an accident.
Anyway, to gfish - if you're using an Aussie seat with ISOFIX clips on the end of a seatbelt strap then the middle seat should be OK, as the straps are connected and then tightened as per the top tether. If you're using a rigid ISOFIX connector then it'd be a fluke that the inner connectors were the standard ISOFIX distance apart, as the spacing will depend on the width of the car itself.
Why do people continually try to circumvent the ADR rules to save a few dollars
Are you and your childrens lives worth it.
Maybe the rules seem to be restrictive but never the less they are the rules and for whatever reason they should be adhered to.
Maybe the seats overseas look the same Maybe they are, maybe they are not. To the Op's credit he said he is going to buy an Aus approved one so why are others suggesting he should look at alternatives.
Always some one who has a "better" way.
i believe that Aus insists on a top tether strap, which to me can only be sensible rather than leave it loose.
