Results 1 to 4 of 4
Thread: Interesting Fault re: The Central Electronics Module
    Mar 2009
    Melb
    I had a light fault pop up on the dash this afternoon and a prompt to check just about every light on the car. Thought I had a blown trafficator bulb as when I indicate left or right, the ticking and lights were quite rapid.
    When I got home, all bulbs were working?????
    Scanned with the VCDS and it indicated a fault with the central electronics
    Interestingly, it fixed itself when I took the car out about an hour later. Has anyone experienced this or have a clue about what is causing this?
    Sunday,25,September,2011,14:07:11:26677
    VCDS Version: Beta 11.8.0 (x64)
    Data version: 20110831
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ9W469134
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 086 HW: 1K0 937 086
    Component: BCM PQ35 M 020 0358
    Revision: 00020000
    Coding: 44180A38982518C044080080140081E443510088436D896064 8000000000
    Shop #: WSC 01357 011 00200
    VCID: EDFF84398A88
    Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 27110 21 0501
    Coding: 009F95
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 111208 05 54 0402
    Coding: 0330AD
    24 Faults Found:
    02382 - Sensor for Light Detection (G399)
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 60720 km
    Time Indication: 0
    Date: 2027.14.18
    Time: 12:13:23
    Freeze Frame:
    Term 15 On
    Voltage: 14.55 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    00061 - Footwell Lights
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 5
    Fault Frequency: 6
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:35:45
    Freeze Frame:
    Term 15 Off
    Voltage: 12.60 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    01701 - Dimmer for Interior Lighting
    006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00100110
    Fault Priority: 5
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:35:45
    Freeze Frame:
    Term 15 Off
    Voltage: 12.60 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    00987 - Lamp for Brake Light; Left (M9)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 11
    Reset counter: 208
    Mileage: 60833 km
    Time Indication: 0
    Date: 2027.14.23
    Time: 08:55:48
    Freeze Frame:
    Term 15 On
    Voltage: 14.60 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    00988 - Lamp for Brake Light; Right (M10)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 18
    Reset counter: 208
    Mileage: 60833 km
    Time Indication: 0
    Date: 2027.14.23
    Time: 08:55:48
    01504 - Bulb for License-Plate Light (X)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 17
    Reset counter: 208
    Mileage: 60833 km
    Time Indication: 0
    Date: 2027.14.23
    Time: 08:55:48
    01493 - Bulb for Blinkers; Front Left (M5)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 208
    Mileage: 61978 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:50:36
    01497 - Bulb for Blinkers; Front Right (M7)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 208
    Mileage: 61974 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:44:08
    01501 - Bulb for Blinkers; Rear Left (M6)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 208
    Mileage: 61978 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:50:36
    01505 - Bulb for Blinkers; Rear Right (M
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 208
    Mileage: 61974 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:44:08
    00984 - Left Tail Light (M4)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:35:59
    00978 - Lamp for Low Beam; Left (M29)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:35:59
    00985 - Right Tail Light (M2)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:35:59
    02394 - Parking Light Left Front (M1)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:35:59
    02395 - Parking Light Right Front (M3)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:35:59
    00979 - Lamp for Low Beam; Right (M31)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:36:02
    01495 - Bulb for High-Beams; Left (M30)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:36:02
    01499 - Bulb for High-Beams; Right (M32)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:36:02
    01496 - Bulb for Fog-Lamps; Left (L22)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:36:03
    01500 - Bulb for Fog-Lamps; Right (L23)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:36:03
    01518 - Bulb for Back-Up Lights; Left (M16)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:36:03
    02745 - Bulb for Daytime Running Light; Left
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:36:03
    02746 - Bulb for Daytime Running Light; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:36:03
    01503 - Bulb for 3rd Brake Light (M25)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 208
    Mileage: 61968 km
    Time Indication: 0
    Date: 2028.14.22
    Time: 12:36:15
    Feb 2009
    Sydney, Australia
    I seem to remember Idle saying his daughter's Golf did this, so she took his car, and then when he tried her car, it was fine. It was ages ago though...
    In any case, keep a record of this, and if it occurs again, get your dealer to look at it, and provide the logs.
    Apr 2010
    Geelong
    Angry
    I have a similar problem but sounds like different warning lights.
    I'm getting very sick of my instrument warning lights coming on intermittently. Has been doing it since day 2 of owning it (now 13 months old). Have taken it to VW service dept 3 times now, including the recent 12 months service. Of course, everytime I take it in, it doesn't play up!!! I posted about this 8 or 9 months ago but no one seemed to reply or have the same trouble. Basically, ALL of my warning lights come up on the right hand clock and my power steering light in the left clock. Right sided lights go out after about 30 secs but the power steering light stays on for another couple of minutes. If I turn the ignition off and start up again all warning lights are gone. First time I took it in I was told the computer was "rebooted" and they couldn't find anything wrong. There was no problem with the steering at any time or any other strange feeling whilst driving when the lights came on. Then about 6 months ago with the cruise control on the lights came back on and I definitely noticed (and heard) a small surge of throttle, increasing speed by about 3-4 km/h. Settles down after a couple of seconds! Then same thing with the warning lights, go out followed by the power steering light. I was not very happy at this stage but again no faults were found.
    After the service 6 weeks ago more warning lights but the last 48 hrs they've been coming on every 30 minutes or so and I'm sure I noticed a loss of power steering for a couple of seconds whilst on the freeway! Yes, very happy!
    I'm taking it back the dealer but I'm sure it won't play up for them! Apart from the MDI not displaying the correct track on my touchscreen very rarely I simply can't fault the car! My Mk 5 GTI didn't have any of these problems.
    If anyone has had similar problems or ideas it would be appreciated.
    2010 Mk VI GTI-Red/Manual/Detroits/Park assist/Leather/MDI/Sunroof/Bi-Xenons/Chassis Control/Elec Driver's seat/5 Door/Tint
    2009 Triumph Street Triple R Matte Blazing Orange
    1971 Mini Clubman GT
    Jun 2009
    That's scary as hell, especially the bit about cruise.
    I think you need to reach someone higher up somehow
