Originally Posted by
coreying
mfl, what is your left hand doing before you move it to the gear shifter to change gears?
Yes I could put the indicator on first and then the put car in 1st gear if my hand was on the steering wheel at the time,(if not on the gear shift already) but with indicator on the right hand side you can do both at once, which what I am (was) used to doing,
as for overtaking Pologti8t, on most occasions on the narrow winding roads (no overtaking lanes) on that I sometimes drive down the south coast, yes you don't have much time to decide,(in order to allow yourself a safe overtaking buffer) a s even in a GTI. Unless you want to be stuck doing 80km/h in the few 100km/h zones that are available.
on the longer stretches of country roads, I don't even bother down-shifting, there is enough torque in 6th gear to overtake safely.
as others have said its an annoyance, rather than a deal breaker.
mk VI GTI, manual, reflex silver, basic
