Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Hydraulic Lifter Replacment
    Jan 2012
    Help and advice needed please. One or some of my hydraulic lifters are noisy and maybe lazy (lazy lifter). Are there any tips on checking these and can this be done by just taking the valve cover off or do the cams and timing chain need to be moved or touched.
    Ozzy
    2015 Golf R. Lapiz Blue.
    Aug 2007
    Have you tried the MBl8 yet and gave it time to work?? haven't heard back??
    Jmac
    Alba European
    Jan 2012
    I was just going to Facebook you. After my oil change yesterday I got my mechanics to see or hear what they both thought. Straight away the heard the noise and said a possible lazy lifter noise and this would also be causing the little miss fires or stumble as the valve that belongs to this lifter is not opening and closing properly. They are going to take the valve cover off on Monday and see if they can spot it and also see if they can change them. Not sure if they have to take off the cams and timing chain. I think if they can do the job just to change them all while the cover is off as I have read trying to test for a lazy one can be a pain if not impossible. Regarding the oil stuff I put it in when I got home and the noise had gone but then again it had got better with the fresh oil too. Car sounds heaps quieter but I still get the low rpm stumble which makes me think we are in the right direction with these lifters. What are your thoughts and any advice.
    Jan 2012
    Looks like it's a trip to VW. My mechanics are not too confident on taking the valve cover off as they think that the bolts that hold it on also hold the cam shafts in place. They are also leaning towards a timing issue too with the noise transmitting from the chain and at the low rpm's the timing is not right causing the knocking and rpm stumble. Anybody's thoughts would be greatly appreciated....
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by Reedy View Post
    To take cam cover off need to remove the timing chain. The bearing saddle on the intake camshaft is left hand thread btw (righty loosey, lefty tighty...). Check timing aswell, MK6 GTI occasionally (rare) has timing chain tensioner issues and/or timing chain stretch issues, there is a TPI I believe, VW are usually very good with goodwill for this.
    Jan 2012
    Thank you mate, this issue is beginning to get to me. Just to keep you in the loop as you sound like The One who could give me advice and perhaps reassure me, at 1200 rpm engine stumbles and top of engine rattles/ knocks closest to the timing chain and exhaust pops. As soon as the rpm's are raised car smooths out and noises are gone. Back down to 1200 rpm noises return car stumbles. Thanks for your advice.
    Jan 2013
    Brisbane, QLD.
    Have you ever experienced it sounding like a diesel when you start it up? (I know that sounds abit farfetched)
    Anyway, I would cease to drive it, or drive it as little as possible.. Book it into your nearest service centre. They will try and diagnose it themselves, it could (hopefully) be something really simple and easy, but it sounds like an issue with the timing chain tensioner. What they need to do is check the timing, ensuring the marks all line up and when they count the number of chain links between both cams (theres a spec set by VW how many links should be between the two markings @ TDC and a MM spec aswell) to ensure the chain hasnt stretched (you can sometimes get the TDC marks to line up, but have excess chain stretch which causing it to be noisy and sometimes make the engine do funny things), this is all due to the old tensioner fitted to 2010 and some later models which was soon rectified. VW will have to assess the damage, sometimes a new chain and tensioner fixes the issue, sometimes if the timing is off could need a new engine, all depends on what they find, but VW will usually goodwill the whole procedure (push your dealer for goodwill!!) Goodluck mate, need any more info just ask.
    P.S: Might also be a good idea on checking intake ports for excessive carbon build up, just a thought.
    Oct 2013
    Could just be a coil pack. They are prone to failing. Change them first as they are relatively inexpensive compared to opening the engine. If you still have the issue then look at lifters. The noise could simply be a noisy injector. Never heard of a lifter problem with these engines.
    MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
    Jan 2012
    Sounds fine when cold starts. Never sounded like s diesel. One thing to note is the noise did get better after an oil change, but did not disappear. When the car is cold and you try and hold the rpm's low the rpm's do jump around more than when it's warm. This results in a little bucking when first driving off when cold but soon goes. I'll keep everyone updated. Goodwill from VW would be nice but I'm a year out of warranty......
    Jan 2012
    Quote Originally Posted by a239947 View Post
    Thanks mate. I put the R8 coils in because of this issue but I might change them back to see as I've got 8 spares lying about. Not sure if this would cause the engine rattle and it's defiantly engine speed related. All other rpm's car is smooth with no noise, 1200 rpm's car stumbles and a top engine rattle. Car still pulls hard. I've just noticed though that the car when still will not rev past 3800 rpm's this is new to me or I've never noticed it before..... When driving I can still red line it.
